Carwyn
Everything posted by Carwyn
  1. All done now mate werent looking at the fixture editor properly
  2. Hi Guys and Gals I Need to build a fixture up, it is basically led tape which I've installed on the steps at the venue. controlls need to be RGB and intensity the controller is a 3 channel controller so how would i get the intensity to control the whole unit then HELP
  3. Thanks for this
  4. Hi All Has anyone go a fixture file for a ETC colour source par and profile. Thanks Carwyn
  5. Hi Has anyone got the fixture file for a Equinox PARTY PAR Thanks Carwyn
  6. 4.8.2.4
  7. 7.8 or 7.8.2
  8. 2 universes, power supply, and a usb stick thats been working fine with the desk for months. Desk has been turned on since 10am this morning been fine all day and between 8.35 and 9.05 this evening rebooted 7 times and there was nobody next to it it stabalised for 10 mins so after that hard power down and power up then been stable rest of the evening for at least an hour
  9. Hi guys Mid show without anyone touching it my lepfrog decides to do random reboots its now done about 6 reboots in about 20 mins power in the building is steady powers plugged in ok. Any ideas
  10. Thanks for the reply but would be nice to have this function i know about the topset function but working on a fiew shows where this function would be handy
  11. Hi guys thanks for the replies just wondering if i could trigger the go button via a midi input from a sound desk able to output midi codes. What is the midi code to trigger the go button?
  12. Is there a way to do an inhibbit channel on the leapfrog it would be great if it could do it with the subs.
  13. Hi Can the leapfrog take midi cue's from the network? What is the midi cue for hitting the go button? Thank You Carwyn
  14. Hi All This may seem a idiotic question but how do you patch channels 97 - 99 on the desk as when your in patch or patch edit you are unable to select them unless im compleately blind. ive been using this desk for some 7 years now and its now doing my head in. theyre visible on the outputs screen but never been able to patch to them Thank You Carwyn
  15. Hi jon Thanks for that. The joys of getting movers in last minuit and going straight into a plotting session. Yip i was the guy that phoned also
  16. has anyone got a personality for a showtec indigo 5500
  17. Hi Is there a command to change the submaster page from page 15 to page 1 in syntax. For Example 'Submaster Page 1' or 'Submaster Page 10' Thank You Carwyn
  18. Hi Is there a easier way to patch rather tHan making your way through the table as in, go into patch then allow you to patch on the external keyboard as in the following format- Channel number * dmx* dmx enter 1*5*7 enter 2*6*8 enter Thanks in advance
  19. Hi Can anyone point me in the direction of the remote software for my computer to run my desk with please Thanks Carwyn
  20. thank you for the information jon
  21. EDIT: profanity removed
  22. is there a way if ive done on my i pod touch via comand line 1>full then is there a way of doing a next button so that 1 goes off and 2 comes on and so on and so fourth. maybee if youve got a channel on like that the + and minus can the change to the next and - changes to previous
  23. is there a way if i had my laptop plugged in as a remote to view one set of images on one screen and different set of images on the other screen if you know what i mean thank You Carwyn
  24. when the film starts we need a command to be sent to the lighting desk to dim the lights a bit whil adverts are on then possibly another trigger to take the lights compleately off then when the credits start lights come up a bit then at the end of the film another trigger to turn the liights backk on again
  25. from our digital cinema projector
