DaveP
DaveP's Achievements
  1. DaveP
    Ctrl + C
    Thank you Peter
  2. If when typing in names for Subs or Memory, you accidentally press Ctrl instead of shift, then C crashes the board and there seems no way out, other than switching off. Moral .... never, never, ever edit names during a show
  3. Thank you for your very prompt reply Kirkup_xp If I hadn't gone to the pub for a liquid lunch, then maybe I would of understood it... Now that bit I do understand .. Yes please, as as a quick / simple method of adding 'jumps' due to last min changes (like on Friday night when Roy Orbison decided 30mins before the doors opened and the tabs were closed that he would sing the songs in a different order, cos he just found out that he had the wrong backing cd.. ) would be great. David
  4. Jumps in the memory stack Only tested on Phantom Frog X so far, but will go and update the board to V3 tomorrow and see what happens. Created a stack of 10 entry's 1. Fader 1 to 100% everything else at 0% 2. Fader 2 to 100% everything else at 0% 3. Fader 3 to 100% everything else at 0% 4. Fader 4 to 100% everything else at 0% 5. Fader 5 to 100% everything else at 0% And so on through to 10. Running the above via the 'go' button, behaves exactly as expected... and all is well An issue arises when jumps are put into the stack 1 Normal 2 Normal 3 Next 7 4 Normal 5 Normal 6 Next 8 7 Next 4 8 Normal 9 Normal 10 Normal The outputs are as follows 1 @ 100% everything else at 0% 2 @ 100% everything else at 0% 3 @ 100% everything else at 0% 7 @ 100% + 3 @ 100% 4 @ 100% + 7 @ 100% 5 @ 100% + 7 @ 100% 6 @ 100% + 7 @ 100% 8 @ 100% + 6 @ 100% 9 @ 100% + 6 @ 100% 10 @ 100% + 6 @ 100% 1 @ 100% everything else at 0% It seems that on a jump, if the last memory was not numerically proceeding the memory jumped to.. then its not cross fading
  5. Maybe this will help to get rid of the bugs
  6. March is nearly at an end .. so not long to go
