pierotec
Everything posted by pierotec
  1. hello, unfortunately I think that "showport" works only with files strand lighting and not with other type such as those with ETC suffix "asc or SHV" regards piero
  2. many thanks, I will make of the tests with this software regards piero
  3. Hello, I wanted to know if you can convert the files *.asc to files *.isf for frog2 Thank you piero
  4. Hello Peter, I make a practical example: with a console type "SGM Studio 12" the signal is recognized as soon as I enter the connector, with other type "Showtec", "Behringer", or "Martin Proscenium DMX" the signal is not recognized or accepted rarely. Thanks piero
  5. pierotec
    DMX in problem
    I found it difficult to synchronize the signal DMX IN. With some light desk is recognized as soon as you insert the connector, with other not detect any signals. Restarting the console is sometimes recognized but may miss at work. You can do something to make the DMX IN compatible with all light desk?. Or the external signal dmx must have specific characteristics. Thank piero
  6. Yes, I'm interested in being added to the list of beta test Thank you piero
  7. Hello, I can not wait to upload the new release. When will it be released? It should also be on Frog2? Thank piero
  8. so it is certainly more correct
  9. Hi, thanks for having considered my idea. Surely everything should remain as it is now. If we need this function can block and multiply the display of the stack that we wish have always on top, for example with VIEW and (SHIFT) SELECT buttons Thanks Piero
  10. Hello, I noticed that it would be very handy have displayed more of a cue / stack window in contemporary. What do you think? Pierotec
  11. Thanks Piero
  12. Hello, I recharged the previous release 4.3.0 and the problem is resolved. Someone found the same problem with the release 4.4.0.? piero
  13. Hi Peter, maybe I expressed myself badly, try to recall a sequence of ten fixture any, one by one and change the parameters with the control wheels (as the exemple that I did in the previous post). In this way my desk goes in crash. Thank for answers Piero
  14. Hi, after the crash the desk does not generate debug file, The crash is systematically with this line example: 1,enter,control wheel 2,enter,control wheel 3,enter,control wheel 4,enter,control wheel 5,enter,control wheel 6,enter,control wheel 7,enter,control wheel 8,enter,control wheel 9,enter,control wheel 10,enter,control wheel this sequenze is exemple, after the 9 - 10 call fixture, the desk go in crash. Can you confirm this with release 4.4.0? Thank
  15. Thank you, I will do tests to see if there is a special command line that triggered the crashes. I did not understand when the desk has created the file debug, where can I find this file? Piero
  16. Hi, i have made an update from version 4.3.0 to 4.4.0. Now the frog2 crashes very often (cross on the screen1) with the previous release 4.3.0 not happening. What can i do ? Can i make a downgrade to version 4.3.0. to see if it should be better. You can also load show saved with functionality asclusive of OS 4.4.0 on OS 4.3.0 Thanks for the answers Piero
  17. Hi is verified or is it just my problem? (UDFin 30 does not work)
  18. Ciao, Release 4.4.0 UDFs 30 no works, Dmx is not assigned Piero
  19. ..... I bought Frog2 after have tried the operation with the offline editor.
  20. Hello, it would be interesting to have an offline editor also for Jester ML. Ciao pierotec
  21. Hi, in the previous version software was possible to visualize on the screen divided into four, about 25 palettes, and this was very handy when you use a exsternal touch screen, in the current software version it possible visualize only 15, in my opinion was more useful to visualize plus pallets on the screen. Thank for your answers Ciao pierotec
  22. Ok! fantastic I believe it is not specified on user manual Ciao pierotec
  23. Hello, it is possible add the recorded macros in the cue? Ciao pierotec
  24. Hello, I working very in theatre and with the headlights hidden it would be useful to moved pan and tilt of the headlights motorized with remote pda from the stage and then create a palette. But does not seem there is the possibility to move pan and tilt by remote control. For the remainder of the remote control is very useful, especially when working with little technical staff, we can do everything ourselves. Ciao
  25. Hello, it would be interesting give different functionality to the DmxIn. For example, activation of UDF or UDK or activation sequences or palettes etc.. Now is just a simple Dmx merge patched, during a live-show is little usable because however easily influenced also by the Clear button. However Frog2 the best console Ciao
