1
Everything posted by pierotec
Hi, I have the same problem with the new release 7.2. The monitors does not works on both my Frog 2, an with old hardware and an new hardware. is there any solution Piero
Hi Peter, I solved the problem, thanks for the suggestions. Piero
Hi, I have not solved my problem You have some information about this? Thanks
Hi, strange, I have a frog2 which should have the same software, the correct syntax is "RECORD CUE n" or "DELETE CUE n" Piero
Hi, I tried a monitor with touch screen eGalax-touch and does not work. Tryed with R6.1, no I tried with previous release. Is there any solution? Thank you very much
Hi, I have a curiosity , as you can distinguish externally, an Frog2 old hardware by an model with new hardware thanks for answer Piero
hi Peter, with the new release the problem being resolved thanks very much Piero
Hi Peter, here are two snapshots with v6.0 and v6.1. They look the same! I hope this can help Thanks Piero
Hi Franck, are the touch screen (type resistive) Chinese production that are distribuited with different brands. http://www.faytech.de/product_show.php?id=11 However, they worked perfectly up to the 6.0.0 release. I can provide the drivers, if they can serve Thanks Piero
Help, my monitor touchscreen no work any more with the release 6.1.0 . You can add the drivers I have on file Thanks Piero
Hi, I can not to communicate my Frog2 with Wysiwyg. I tried several ways but always Wysiwyg this message (image 1) I state that everything working using PhantomZerOS, but Frog2 does not work. Restarting the desk you see this message (image 2) Thank for answers
thank for the answer, works also with interface enttec dmxpro usb...and dongle, naturally. Hi Piero
Hi, you can activate an output dmx on phantomOS. If so, how Thank
the remote monitor for IPad is very very good, I would have preferred an window "panel" with keys plus big and command line present Thanks Piero
Hi Jon, when using "panel" on desktop monitor, the page number display change in continuation piero
also update stack/cue I noticed an anomaly. The stack 1 appears to function properly stacks 2-3-4-etc. occurs this problem shown in photos thanks to you, I work very well with your products best regards Piero
yes, but the release is 6.0.0. selecting UDK 1/1 the button not turns red, and the command line turns red for error sintax
okay, however the problem is also viewable on PhantomZerOS Hi Piero
in particular update on the UDF and UDK. using the graphical interface on the touchscreen, the sintax is not complete I hope I was clear thanks
Hi, in release 6.0.0, the update window not working properly or not I understood Thanks Piero
is alredy available the application ipad monitor? ciao piero
Hi, this release is compatible with all frog2, also older hardware? Thanks Piero
Hello, I had already reported the same problem on my frog2 old model, I resolved to return Release 5.3.5. Hopefully a new release that solves the problem on our old desks (I have two USB ports on front) Piero
