1
Everything posted by pierotec
Hi Jon, you can create a special version of your main library for me with this fixure attached. Thanks Piero
Hi Jon, yes, I am a beta tester :-) piero
Hi, is possible to implement the midi show control also on the Frog2. Regards piero
Hi Jon, here's the file. Thanks vl2000spot.ift
Hi, I'm changing some parameters of a fixture with Fixture Tools. Everything works correctly, the only problem is that after the desk reboot the gobos icons disappear on the palette, why? Piero
Thanks Jon and Franck, the desk is frog2 new hardware, one USB (on the old frog2 from zeros7 onwards does not work well), the current release is 7.6.0, probably I was wrong to attach the debug file. I check and attach the correct file, sorry.
Hi, -when using the syntax RECORD GO to a sequence of multiple cue, the desk crashes. attached the debug file. -when using the direct channel selection from the Output Window and press Enter once you activate the syntax Enter Enter. -as you activate the 'solo' on Frog2 ? -strange viewing when and active TIME in the palette (picture below) for the future: -because it not enable the syntax PAGE n, very useful in creating macros for example. -you can add in the setup the time default also for the palette? as for UDF UDK etc.. excuse me for my suggestions, I think they can be useful for many. Thanks piero debug.dat
Hi, how can I open an ascii file or txt on frog2. when it is loaded only displays the list cue, with the crossfade time, triggers etc.. but no patch channel. Piero
Hi, I would like to use the internal CD player to the console syncronized to a cue list to send audio. I noticed, however, a poor quality audio in output jack from the console (distorted sound). Is there any solution to this problem? Piero
problem with TIME RECORD UDF. example: on my frog2 when record TIME on UDF10 (or else) and click GO button on stack 10 (or else), turn on and off the button UDF10 (activate time). I hope I was clear Piero
Hi, you can find out what's new in this release with the release notes. Thanks Piero
I get it! but why this feature is not present in the top desk? Piero
Hi Jon, I do not find this setting in the desk setup ??? Piero
Hi, you can make a patch dimmer to channel in live mode, example: 1 (highlight) @ 5; highlight function is to locate the device or dimmer on stage during the patch. Excuse my suggestions. Thanks Piero
Hi, it would be possible to add in a future release the possibility a various patch curve on single dmx channels?. It would be also possible to implement this syntax: eg. CUE 1/1 THRU 1/5 TIME x/y. Thanks Piero
Very very thanks, Peter and Franck. Zero88 the best. Piero
I have given this files......??? files Memorie Spark.zip
Hi, can be convert a simple cue list with only dimmer channels by Compulite Spark to Frog2 Thanks Piero
release 7.4: is available on image CD? Thanks Piero
Hi, I use the application for Ipad. I would like to know if your application for tablet Android is equal to that for Ipad. Thanks Piero
Hi, I have two frog2, with a new hardware and one with old hardware, this seems like a problem that occurs with consoles that have old hardware, but still work regularly. Piero
