1
Everything posted by pierotec
SHIFT [Parameter] RECORD Playback. I tried to use this procedure to store a parameter on a playback on new console flx s, but it doesn't work anymore? π P.
Hi, I found the UDK keys on the old Frog2 very practical, where different functions or effects could be stored, etc. and immediately recalled. On FLX there are only four (for page). It would be interesting to expand this number, obviously since it is not possible to do it physically you could insert it in the "Multi Funcion Fader" screen and call them up via touchscreen. It would be nice to do it also on FLX S. Thank you P.
there is the possibility to download version 3.1 of the remote for iPhone to use it with Frog2. Piero
for the future it would be interesting to be able to use a midi usb or ethernet interface in order to use the timecode function or midi show control P.
ok, itβs right. I noticed that in the program window of the external screen the values are in percentage so I'm fine too, I would have preferred to the contrary, program window dmx e wheels percentage. π Thank you P.
Hi, as I wrote also on another post, I think the current remote app should be able to be set to work with the old consoles while maintaining the old features. otherwise changing smartphone we can no longer take advantage of the remote app on our consoles. P.
I believe reality it is easier to display a position or color parameter etc. in percentage, instead of example 65,500
it would be useful to setup on remote app the old or new console, in order to use the same app for all the console
Apple Watch π
Hi, I work with the flx console and the "old" Frog2 (for me it's always the most flexible). With my smartphone and smarduckch I would like to use the new features of the remote control with the flx and be able to use at the same time my smartphone with the Frog2. There is a solution? can I use two App on the same smartphone an updated and an old one? The problem obviously is that the new updated remote no longer works on frog2
perfect, can also be done something on flx s? Thank you
Hi, I noticed that it's gone Edit Fixture in the Setup on last consoles. There is only the possibility of reversing pan tilt and little else. Previously it was possible to set the console also default parameters (very important to me), levels max etc. it would be nice to be able to reintroduce them Thank you
It does not seem to me that it works. I will try again but it is not very comfortable however on the old zerOs on Frog2 the type of visualization was settable Thanks for your answers Edward
Hi, how can I configure the percentage display on the encoder wheels Thank you
Hi, how can I configure pause on a cue/stack, without excluding the GO button. Thank you
with the 7.8.2.39 update the fixture library 33 has been loaded regularly P.
Help, I can not load gft33 in my frog2 zeros 7.8.0, at the end loading from memory error. do I have to update for strength? Piero
Hi, I currently work with zeros 7.8.0. What are the differences with zeros 7-8-2-39. I have no problems with 7.8.0 and I do not want to risk updating uselessly. Thank you Piero
sorry, it was just a connection problem. you can delete the post Thank
Hi, the new remote release does not work on frog2, how can I go back? P.
the beta version of 8.0 had already been launched more than five years ago with pixel mapping..
Hi, qlab is very good with timecode you can command the show in ZerOs console. It would have even good to have in ZerOS the midi notes function or midi show control and have even the midi out on the console for trigger the qlab. P.
