pierotec
Everything posted by pierotec
  1. I can confirm that the Flx S48 console worked well using about 2000 channels with 2 Artnet node and 13 used universes
  2. I'll let you know soon πŸ˜‰
  3. Why, have you noticed problems with more than 1024 channels?
  4. All clear, I'd already done some tests in the meantime. With current fixtures, it's very easy to manage a significant number of channels, but 2048 channels is a good number for a console of this type. I was more interested in being able to use many universes. Thank
  5. OK, it seems there's no limit up to 64 universes, even though the specs mention up to 4 universes. But going into more detail, I can, for example, manage 96 fixtures of 40 channels each across 12 universes and therefore manage 3840 channels, because in this case too the specs mention a maximum of 2048 channels.πŸ€”
  6. Hi, I need to connect my FLX S48 to a lighting setup that uses 12 universes. I'd like to confirm that the console can manage the 12 universes on the RJ45 connector using ArtNet 4. Obviously within the limits of the fixtures that the Flx S48 can handle. Thank you
  7. Thanks Kgallen, I reproduced it in the channels mode I needed in no time with Fixture Editor πŸ˜‰
  8. is it possible to transform a .zfix fixture file from my s48 into an .ift file to be read by my beloved Frog2 without rebuilding it with the Fixure Editor. Thank you P.
  9. yes it is one of the first versions when the single-universe version was also in the catalogue, but it was already set up with two connectors. so with release 8 the second port should also open?
  10. Hi, is it possible to upgrade from one to two universe on a flx s24? thank you P.
  11. Hi, it is possible to convert a fixture file .zflx to .ift I tried with Fixture Tools software but .zflx is not accepted. Thank you P.
  12. Hi, the possibility of having a customizable multi desktop as happens for example with Orb is very important, I hope that it will be taken into consideration in the next updates. Thank you P.
  13. solved with Startup Tool. Thank you P.
  14. …then tries to reboot again but to no avail. I read in the manual that it is possible with an external keyboard by pressing F1 to enter a service menu. I'll try this procedure tomorrow morning.
  15. asks to insert usb stick to save file to send to Zero88 support
  16. Hi, I have a problem with a flx s48. After startup it asks to insert a memory stick, saves the file but the console does not start. How do I fix this, I have an upcoming show.
  17. it would already be great to have multiple Playback cuelist windows displayed at the same time πŸ˜‰
  18. Hi, it would be interesting to be able to customize the windows on the external screen as in the old frogs. Example: hold down the Wiev key and color, group, playback, etc.,and then press the view key until the active window is positioned in the desired position and size. Sometimes it might be useful to display several cue lists at the same time or a full-screen color or shape window. Sorry for the suggestion it's just my idea. Thank you P.
  19. Thank you Edward
  20. Hi Edward, it would be a feature that could be implemented by taking advantage of the large number of faders available. It would be very useful in quick editing of theater cue stacks. In the old Frog2 it was possible to do this on UDFs or UDKs. Thank you P.
  21. of course, only the intensity is stored in this way. A group should function as a channels page fader. P.
  22. Hi, it is possible to assign groups on the faders? It would be a very useful feature. Thank you P.
  23. Thank you
  24. Hi, it is possible to urgently have the fixture for DTS nick 1401 NGR 20 channels for flx S48 7.9.7. Thank you P.
  25. the 2.1 library is not opened by fixture tools 2.6, why? P.
