Hi,
I'm the LD ice told you about. I was having the exact same problem (if I understand all your lingo right). I saved a static position pallet, and when recalled using a memory or a submaster (after a reboot) the static pallet changed itself into a moving one.
The strange thing I think I noticed is that if I loaded the show from a floppy, this effect happend, but when I loaded the show from flash ( essentially just turning the frog on) this problem wasn't encounterd. This wans't an option for me though, because the flash memory tends to forget the submasters.
Unfortunately I don't run the show anymore, so if you have further questions I'll have to try to remember.
Good luck finding the problem!
Enrique.
ps. I'm glad other people were also experiencing these problems, I thought I was losing it
