glenn
Everything posted by glenn
  1. We have released Version 10.12 of the Frog Range Software. The new operating software, offline editor (Phantom Frog) and release notes can be downloaded from the Zero 88 Support Centre: CLICK HERE dose not work??
  2. Thanks Peter for replying. I moved missing colors to beam shape wheel. it is what it is. Maybe John will add/ make a fix???? Glenn
  3. We you ever release any more software for frog range??? Glenn
  4. I made a profile for this fixture, but desk only shows 6 of the 8 wheel groups??? Please help Glenn ADJ-SWEEPER.ift
  5. Can you still use elo screens? If so does it matter on which ones?
  6. Hey I looked on the cooper site, for some of these items. I can not find a cost for us. I was set up as a dealer though A.C.T. How do I get a cost and can I get dealer pricing again. Glenno@eliminatoraudio.com
  7. Hey can you use the LF playback wing on any console?
  8. I see that. What do I need to set up artnet?
  9. Thanks for the repley. I just need to clearafy. I have a leap frog and a leap frog 48. I would like to use the leap frog as a play back wing. One which console do I up 30 max submasters. Will i be useing the submasters or the dimmer faders on the leap frog desk. Glenn
  10. What is need to get all four universes up and running, parts and set up?
  11. Hey ndo I sey up my Leap Frog to be a play back wing Glenn
  12. Hey Jon, I have one more Irrdiant fixture that I need. SRL-6041 DMX channels: 5 Channel function: Channel 1: Red intensity Channel 2: Green intensity Channel 3 Blue intensity Channel 4: Dimmer Channel Channel 5: Strobe speed Is there a list on this forum for made up fixtures? I belive there was one at one time? Thanks Jon
  13. I was thinking the same thing. I see no other repl.
  14. Irradiant LED Color Bank 12x8 (SRL-6018S-3W) and daisylight Square DMX RGB LED Tube same as in header topic thanks much
  15. Hello guys Im looking for fixture profiles for Irradiant and Daisy Light products. Does any one have some already going on old school Leap Frog Thanks Glenn
  16. I'm working on a Fat Frog. It does not satrt up. In the past the owner said it would lock up and they would restart it and it would run. Is there a reapir manual or techincal repair sheet or something else?? Thanks Glenn
  17. When adding dimmer channels to other channels. We were trying to patch channels 33-40 to channel 24. After doing this these channels would come up on the intensity wheel. Is there a way to patch dimmers a different way? Or faster way? Glenn
  18. I am looking for a profile for the Elation Opti RGB. Thanks Glenn
  19. Hi Gram, I can not pm on the board for some reason. If you would like me to arrange a demo for you I can do that if you want to PM me your details. I can also ask our US distributor to try and put you in touch with some users in your area.
  20. Why is it not bad? What did you have before? What are you running on it (fixtures etc.)?
  21. I'm looking at getting one. I use a have leap Frog now. Would like currtent user inout from one. Glenn
