Haytech
Everything posted by Haytech
I´ll do exactly like GLX despite the noise boys intolerant behavior I do my work like them all I´ll never go to discuss totaly worklight blackout with noiseboys... I´am the master of lights... others have to beg for light :twisted: and power .. Last but not least they all have a flashlight with them why don´t they use it ?
Hi I have a suggestion for Halo_djk: Create a movement effect with on-board effect generator for your moving fixtures now while the effect is running create a colourful chaser. Transfer to SX button. The SX - button should now recall the colorchase and the movement. Hope this makes sense to you.
Hi, the LTP Fade time is to create slow fixture movements by stepping thru the memories. If LTP fade is set to i.e. 00.03.00 then a movement takes 3 sec another movement programmed in a chasestep is blocked by the LTP fade too so it is nessesary to set your LTP fade to 00.00.00 P/T speed is a dadicated fixture feature so some of the fixtures dosn´t have it. In this case it is recommanded to set the chase attack modifier for Pos to <fade>
Hi Dr Chinchilla, RTFM :mrgreen:
Cars knitted with hot knittingneedles. The second and the last ford I ever drove was in garage for more time then it was on the street. I think it was the good working garage why this car never works proper. that was the reason for me to switch to VW :mrgreen: Sorry for OT
@GLX 12V is little voltage with big power. Once my Ford Focus is burned out while they build in a new heater - my garage didn´t have a good car electrician :-( Gladly the insurance bought me a new car. MfG Sebastian
@GLX its a question of faith in all kind of electronic stuff. I disconnect my TV,PC,Lamps etc. from mains when I leave my flat.
I wonder, that the herpetologist out of all people around has difficulties with this little screenjumpers.
I don´t want to panic, but there is a risk of fire, when you don´t disconnect the PSU from it´s power plug.
OK for forum users driving on the left :mrgreen: KLICK HERE FOR FUNNY FLASH GAME
Hi, Chip user of www.paforum.de found this funny flash game. I needed 3 trys to get the clue.
Hi PatrickK, have you already checked the Main PSU power outputs ? they should be +5V and +12V regards
Hi, Vote me in for deactivating autorepeat I don´t like strobing anyway :-)
Hi, if it is as Gabz described it is a painful strobing - as it ends up killing some lightbulbs and fuses *g* I won´t try it while our dimmers connected...
Hi, pallettes refer to the LTP values color,beamshape,position to any kind of fixture. There is a way to use pallettes on generic lighting but it isn´t advisable as you can´t correct LTP values by rising or lowering any fader. You can still insert a copy of your memory. And if your scenes 1 and 2 are already programmed, then copy your pause scene to memory 1.1 regards Sebastian
Hi Zero88 folks, HAPPY NEW YEAR 2005 all the best luck for Frog 2 launch. It would be great when this bug is solved asap. Many thanks Sebastian
Happy new year Ice, No, all fixtures that are tagged will be affected by the pallette call. I.E. 6 MAC 500 Color is setted to open stored on pallette 1 all Color is setted to red sored on pallette 2 now home color data for all fixtures tag fixture 2, 4, 6 press p2 and violá Mac 2,4 and 6 are red. This circumstance is very useful as you can store one pallatte for each color for all fixtures used.
Hi It´s kind of a Wer-PC that crashes at midnight.
Hi Franck Thanks for your quick advice, I will try that. all the best for 2005 Dir auch einen guten Rutsch
Hi maybe it is possible to add a "diagonal line" to the effects I have seen those at some other desks before. regards and happy new year
I wish Happy Holidays to all of you too Einen guten rutsch !
Hi Ben, choose the partial mode - this increases your possabilities. In partial it is possible to get submasters with generic chasers and have others with mac or chroma chasers. why do you group your macs together ? fatfrog has 12 fixture channels if you give each mac a fixture botton you can get great effects.
Hi sam, as Martin explained right the desk have to be in partial mode: Desk Setup - programming mode - partial and all fixtures have to be untagged press fixture button until yellow LED stay´s lit while you program new chases or scenes, because the submaster call and send stored LTP values (position/beamshape/colour) at 5% output. It is possible that a submaster calls only one of the LTP values: set your "new scene - par 1 & 3 scanners go to red" press colour button and program. hope this helps
Hello, I would really like the "desk use lock" too, as some people (esp. pubescent grown ups) playing with the FOH desks without supervision until we are on catering :-b
You have to connect a real existing frog console or another desk via DMX to the WYG-IT as you need a DMX outputting processing unit. The phantom will not going to output DMX data.
