Nico
Nico's Achievements
Newbie
Newbie (1/14)
  1. it's not a joke... more fixiture you have, more memory you need... and the mambo give you less when you want more... is that possible to add memory? or in the futre, is the hardware be abble to do this operation?
  2. -) don't know if is correct: the mambo frgo has 400 memory block (and if ) make chase of 100 steps, it will be 300 block avaible for scene)... but the step of my chase, can ) use them as scene? -if the mambo frog has only 400 memory block, why 999.9 different numbers possible? -the mambo frog has preprogrammed movement, like circle... if ) make a movement, can ) save like preprogrammed type or must ) use the 400 memory block? (and if it's possible to spare the memory bloc, can ) save the movement only?)
