GLX
Everything posted by GLX
  1. Well if you come to a gig with no maglight you deserve to be left in the dark.
  2. Switch on the overide on a dimmer channel from your pack, apart from that plunge those noise boys into darkness.
  3. You should use the pallets for changing colours live. Hopfully K-Nine will push for the fade in/out times on the pallets so you have the choice to fade or snap your colours or gobos. Would work great with the wash fixtures.
  4. Moderation: Split into separate topic and moved to Social Forum Well all my kit lives in the back of my sprinter and there's only 12v knocking around in there
  5. Fu*k it, twas simple, agh well its one for the noise boys.
  6. GLX
    Turning On?
    The desk pulls dam all of a load, cant see how a fire would start :?:
  7. Well any answers? :?
  8. So you're going to think about it, but will it happen?. Have the option to snap or fade pallets.
  9. !!!!!!!!!!! Is there an answer!!!!!!!!!!!!
  10. You can adjust the contrast and brightness in the superuser menu for both displays. It's under desk setup (I think)
  11. GLX
    Demux question
    Q1, Has anybody come across a demux unit that can do both +10 and -10v at the same time via different outputs. Q2, Can analog dimmers be changed to accept +10v, instead of -10v?
  12. Just press it once then, why would you want to wreck your gear? :roll:
  13. GLX
    name!!!!
    Bubble popers
  14. Would it be possible to have a fade in/out time on pallets, would be great when using the CYM in the wash lamps.
  15. GLX
    USB
    Would it be possible to install a usb port into a fatfrog in place of the floppy drive, I keep breaking the disks.
  16. GLX
    SMPTE/MIDI/CAN DMX in
    How about installing the fixture editing tool into the desk, so if you come across a new fixture a personality can be writen easily?.
  17. That looks so like my bank,loads of happy people. :cry:
  18. FIREWORKS!, it's so cold here you would'ent put a milk bottle out :cry: , here's to a mad busy new year, may your bulbs strike first time.
  19. Ta.
  20. I installed a Alcora 24/48 into a venue yestreday, question! howmany shows does the memory storage unit hold and can the info be wiped?
  21. Pop out the dmx from the desk
  22. When programming make sure the MEMORY MASTER IS AT ZERO,and when you finished programming your chase, home the fixtures and bring the dimmer channel to zero. Do mini macs have a dimmer channel :?:
  23. GLX
    Scrollers!!
    Before sombody brings it up, NO a bigger desk is not an option unless NZ has a leap frog he wants to set free . But back to the question in hand its a head wreck :|
  24. GLX
    Scrollers!!
    I'm using 8 scrollers and 12 nodding buckets on a fatfrog. The nodders have claimed the 12 fixture buttons, so i'm using channel 40 to 48 as scroller control. NOW the trouble is when i save the scrollers to a sub(say the third gel in green) and replay the scene and rase the sub the lamp level rises but you can see the scroller gel rolling until it reaches "green". Is there anyway around this without programming scroller colours as memories.
  25. Small bits of gell 8O
