GLX
Everything posted by GLX
Yep, choose your own keys, and just pop a sticker over them. Would this effect the naming of subs,memorys etc...
You could always use the same method as naming a saved show................................................................ A PEN!!
Well if multiple chases can be run from the subs, why not pick a sub page load all your chases onto it a bang them out from there?, after all there is 20 :wink:
What about the hand cramps from tapping a step button for a while, yes we've all got it at some stage of out lamping lives :cry:
K-nine wouldn't know just look at his keyboard
Pinspots dont dim that well!, they start to do a strobe thing. Think it's the trafo having a fit. :cry:
Well if you ever feel the urge to play with 7 faders, it's just the ticket
At last it works :roll:
Keep it simple people, if something goes duck up twill be easy to locate the problom 8O . Run two snakes, one to dimmer world and the other to the movers and use memorys for the movers and chases while keeping the subs for statics. Sit down and find out what you want to do,make it simple to program and simple to run. Pointless wrecking your head when you dont have to. :wink:
Keep the generics on one frog and the movers on the other, the word custom, is this a homemade buffer? post a photo
Good man must try that! :idea:
K-nine could it be done from the keyboard, "memory 1 +50 enter" and then press go in the desk. While on the subject, on a theatre gig when trying to find lamps could just entering ie... 50*70enter.. bring up all channels 50 through 70. Would be a handy tool.
No probloms here! worked first time on a well toured disk. Format the disk on the frog, then save the upgrade to the disk via a pc, insert into desk power up and hey presto, more things to remember!!
Cat5, 4 pair with screen cost 30 euro for 600m. It's install stuff so you wont be rolling it up too handy.
One thing to remember, when you program your last memory place a jump to memory one or you could trigger memory 999 and bring all up during your show! not so good.
Try:: Black out button pressed, pin3 + pin 2-on your DMX cable, Are your faders patched to dmx, failing this go have a cup of tea then come back. Goodluck.
Buy yourself a drum of 3x2.5 TRS and run your own hots to your rig, running movers via the dimmers is NOT an option, you'll trash your movers and kill the triac in the dimmers. It's a cheeper option then replacing a trafo in a mover :?
Maglites to full and leg it, 9 times ouy of 10 it's the hazer that will set it off. A 32a BREAKER on the dimmers your just asking for trouble there, get it sorted out!.
Yep!, rase both subs, containing lighting sceans select an empty sub press save! as easy as that.
Make sure your mac's are in mode 4, and the personality loaded onto the desk is also mode 4.
Are you sure they are 250+ units?, when selecting gobos the first time round the gobo wheel they will index, second time around they will rotate. Make any sence to you.
If I thought I could get away with it 8O :idea:
What kind of money (euro) would six buttons from the frog range cost? making up a remote switch bank for the fatfrog and would like all buttons the same.
Thats what happens when you plug welders into your dimmers as strobes yes I've seen it done, just the once. Welder 1 Dimmer 0.
Well after all they can only count to two
