GLX
Everything posted by GLX
Did anybody spot the Zero88 fatfrog in the new fantastic four movie?. And not a lamp in site.
Its the old martin protocol, the board makes no sense to me. If the scan accepted dmx then no probs but I'm not spending money on a martin converter for a mess around project in the stores. Found it!! lets see who can build the next huge thing in lighting http://www.milinst.com/DMX/dmxtext.htm
Has anybody out there got a simple way of controling stepper motors.(not via a frog). Ripped an old martin 218 non dmx unit apart for the duck of it and was wondering how would i be able to control the motors say to pan and tilt a video camera. Keep it simple. 8O
Try plugging the desk into another mains supply, if power failed the outlet or circut may be damaged.
How long did it take to strip the desk and rebuild it? any bits left over?? 8O
I did a show there a few years ago, the desk was straight from flash gorden and crap faded washes. Most of the rig is used as punter lighting. :cry:
By any chance was Speedy anywhere near the desk, he has the touch of death when it comes to lighting. 8O
Well been lazy at a gig the other day, instead of running my dmx snake I jumped into a spare channel on the noiseboy's multi. BUT! unknowen to me the monitor desk was been used for the gig, and yes it happened the monitor noiseboy turned on the phantom power on the channel I was using for the dmx, the nodding buckets and dimmers went mad as a result of 48DC volts attacking there soft bits. Now the fatfrog seemed to get away with no scrapes but I'm down six 6 way dimmers and two mac kryptons. :cry: So fellow lampies ALWAYS RUN YOUR OWN SNAKE!!!! :!:
You can pick up 12v bulbs in all car accessory shops
Anything happening in Ireland?
Whats for lunch? lampies never miss catering
The next time you have access to the movers, program all your pallets first then save the show to disk and write protect the disk. Then next time your stuck for time load the disk and bang it out.
So thats what the manual is for! I was using it to stop the dimmer rack from rolling off the stage Very handy for that too 8O
WOW a bit mad on the eyebrow department!!
Keyboard in a 1U drawer at the front, TFT under the desk. Case on wheels easy to push. On the lefthand side of the desk a storage area for pens,disks and pvc.
Get a flight case with a small "dog house" at the back Plenty of room for the PSU and getting disks in and out.
Step1, Are all DMX addresses correct on the movers Step2, Are the fixtures patched on the desk, and the right personalitys loaded. Step3, Look at the movers and on the dmx input it should be pin 3 +, and pin 2 - If all above does'ent work, wipe the desk and reload and readdress everything again, it will save a "brain boil".
The following kit is for sale as a package, 4 x mac 250+ c/w twin cases 4 x mac kryptons c/w twin cases 2 x GLP colour wash 250 c/w twin case 8 x source four cans(copys) c/w 575w lamp & G-clamp 2 x Showtec 4 way dmx truss mounted dimmers 4 x 2 lite blinders c/w G-clamp and lamps 1 x 32A to 6 16A distro + 1 martin 4 way dmx buffer 1x dmx and mains package in a mac 250 case 8 x Global truss F34 3m box truss sections 4 x LW 265R truss stands c/w truss addapters. (220kg, to a max 6.5m each) 4 x 1 Tonne manual chain hoists. (15m lifting chain) 1 x Spanset and shackle package. 1 x Zero88 fatfrog c/w flight case on wheels 5 x 10' x 25' star cloth sections 2 x 12" mirror balls c/w motors and G-clamps. 1 x Rosco 14m x 10m black projection screen 2 x Morpheus colour faders c/w 8 way psu. 14 x MSD 250/2 used lamps, 600-800 hours on them. 40,000 euro Selling up and moving on. :cry:
Buy a cheep dmx hazer on www.thomann.de and be done with it.
If its a cheep fitting the gobo wheel is the dimmer, not much you can do.
Must have been hanging around the riggers too long, second hand smoke can still send you tripping 8O
Are your scans and dimmer packs pin 3 hot and pin 2 cold, if not this could be the source of your errors.
Try unpluging the dmx lines leaving the desk before you go into the dark depths of the super user, keeps all your lamps lit. Any help?
They must have found the box of switch's that were for the frog 1 range and gone mad and put two on the frog2 Agh well better looking at it than for it.
How about a 12 fader extension wing, could make you a few bob!! Mine however shall be free. :wink:
