CyberLight
Everything posted by CyberLight
  1. Hi, Well, this problem seems to be a familiar one. I have this one also. I'm using 4 trackspots on the table. Starting from dmx 50. I usualy have the problem on bank 1 subs 1 and 2 and occasionally on 6. I'm using op-sys 8.1 tia, Philip
  2. Hi, How can I copy (or better yet move) data from one fixture to another? Here's the deal. I have a big show coming up in march. I need to light 2 stages from one fat frog. I have a complete show programmed with four trackspots. That's for one stage. The other stage will also have 4 trackspots. But instead of programming the whole show again for the second stage, I want to copy all of the data to new memories (this part is going ok) but then I want to move all the fixture data from the first 4 trackspots to the second four trackspots. This way I can get two separate shows on one desk. How can I achieve this? :?: For your information: There are 8 trackspots patched. All addresses are correct, the desk is in partial mode. For the first show, only the first 4 trackspots were tagged. I program all the data to memories, before I transfer them to the submasters.
  3. Hi, I am a new Fat Frog user. Actually I did only one show with my new desk so far. I have two questions about the usage of the submasters. I have the desk in partial program mode. I programmed a few scenes with and without fixtures to the submasters. Now the following happens, I have a submaster up, which only contains fixture data. Next I slide up a submaster with only generic data (i.e the frontlights). My fixtures (trackspots) will go "out". I thought programming in partial mode would give me the oppertunity to program my fixtures "transparant". How can I achieve this? Second: With the use of submasters the fixtures will snap in at the trigger level. This is ok for the LTP-parameters, but not for the dimmer. I want a slow fade in for the fixtures. I tried timed and un-timed transfer to the submaster. Both with the same result. How to do this? Thrid: When I fade my submaster with fixture data off, the fixtures will stay on, whilst the generics fade out as supposed to. Only the master playback X will work. Shouldn't my fixtures have to fade out on their "own" submaster? Fourth: I have programmed some scenes with fixtures to my submasters. Changing from one to another submaster will result in a snap beteeen the scenes. This is strange to me, because I have programmed a mirror speed of the fixtures into the scnenes. So the scans should "walk"slowly to their next position. I fixed this by programming a chase with only one step. But shouldn't it also work this way in a scene? I know these are a lot of questions, but I hope someone can help me. tia, Philip Koning
