Pipo
Everything posted by Pipo
I think LXKEV is right, make the "ULTIMATE FROG" and i will be the first one to buy it!!(with a big discount)
Can you tell us a little bit more about the update? What are the new features? Individual parameter programming? :twisted:
Put your desk in partial mode, press and hold colour and then program! The same for beamshape and position. To program only brightness make sure the fixtures are selected but not tagged(yellow led may not flash) and press program.
Can't you add the offset parameter to color or beamshape just like you can make a movement-wave you would be able to make a color-wave using the fan-and offsetfunction? Or is offset ONLY for pan and tilt?(what i simply do not understand)
submaster lcd display!! focus sunmaster+other stuff :-s
Pipo replied to lxkev's topic in Frog Range MK1
Maybe if you kiss your frog it will change into a pearl? :twisted: -
the same that offset does with pan and tilt when using the fan function, but Franck already told me that it is not possible!
Is it possible to add the offset-function to color and beamshape, would be a nice feature! Can't be that difficult.
Maybe... If you make a new fixture with only one parameter (position), and use it as a conventional(generic lamp), then i think it would be possible to program it to the positionpallet. BUT: brightness is a htp-parameter and position is a ltp-parameter so i don't know how it will react once you will transfer it to a submaster. Maybe the men at zero88 can make it possible in the future to turn LTP into HTP parameters so when you have a position on a submaster you can easely control the speed of the fixture going to its position. Please try it out and let me know
Is it possible to put a few more shapes in the shape generator? I know I have the frog-function but it is not what I want! I just want to make a few effects without having to program for few hours. Thanks!
if you program your scenes into the position pallet you can use them to create a chase but i don't think that you can use the copy-function to put scenes into chases.
The sirius was based on DOS and according to me it did crash to much. The output on the frog however can be better so you have a better overview. But haven't got any problems so far with it.
Can you send me a printout of the patch. Cheers
How can i calculate the home position for a moving head, read it a while ago , can't find it back
I was hoping that this would be possible, is it going to be possible in the future? I've got me a mambo, because i've read on this site that it would be in the next upgrade! And it doesn't matter if the interface would be difficult, one could program a show much better if it was possible to program individual parameters
1) is it possible to make the pallets work stand alone? -->what i mean is that when you lock the pallet-screen, it should be possible to select the required color or position without pressing the attribute-button. 2)when you have, lets say, 4 moving-chases selected on your sx-buttons, then is it possible when you desellect them it goes automaticly to the previous one? 3)overlapping memories -->when you have a few positions programmed on your pallet and you have a simple position-chase(going up/down) then would it be possible to make the chase work on every position programmed in your pallet by just selection the position when the chase is active?
Use the Boss DB 88 digital metronome and connect it to your audio-input! And you will have your "Tap Tempo Box"
why not? You can't show everything on that little display!
had this weekend the same problem twice! But!!! I've found the problem!!! This time i needed to insert memory 10.1. When I did that I could not see it on the screen! I changed the mem.type from scene into chase and memory 10.1 was suddenly vissible! Can u tell me what is the cause of this?
I used a mambo, Started at memory 1 to 1.9, 2 to 2.9 .... at memory 8.5 nothing! They were all very short memories 1 or 2 steps. I will send u a copy as soon i get in the warehouse
We had a large show this weekend, so i started programming When i've programmed memory 8.5 i wanted to insert memory 8.6 but no, it was not possible. I just couldn't insert another memory! There was no warning that the desk-memory was full or something like that. So i had to stop programming! Switched the desk off a few times but nothing would help!
Is it possible to add modifiers to the built-in movement-effects? I just want the possibility to set the movement-effect in reverse e.g fixt 1,3,5,7 movement ellipse fixt 2,4,6,8 " " reverse
When i try to clear a pallet the desk starts saving the show!
Im i blind? I can't find the power-switch on my mambo-frog! :evil:
