AlexP
AlexP's Achievements
Newbie
Newbie (1/14)
  1. Otherwise I have installed the latest version of the software and thanks to you and your fixtures profiles that you provided me. Everything works. Thank you very much
  2. Once the 7.14 software is downloaded and my show file too, the text in the Fixture Patch is red and nothing works. DMX addresses are good. After removing some devices from my list, I reinstall them using the library data (red text). It doesn’t change anything For information, the technical team of Zero 88 answered me this. Maybe that explains my problem The software installation process completely removes all data on the console, including any current show files. With showfiles saved in ZerOS 7.13.2 or earlier, some Colour Effects on RGB fixtures will need reviewing due to ZOS-4780: • If using a colour effect on both RGB AND CMY fixtures together that was manually created using "waveforms" (FLX) or was created by modifying an Auto Palette (FLX S & FLX), the RGB effect may be out-of-sync from the CMY effect. • If using a colour effect on RGB fixtures that was manually created using "waveforms" (FLX) or was created by modifying an Auto Palette (FLX S & FLX), the effect may look different than previously. Accessing Fixture Macros has changed (see ZOS-9605). Therefore, Fixture Macros within showfiles saved in ZerOS 7.13.2 or earlier will not be loaded. This should only affect users who have stored a Fixture Macro onto a UDK (User Definable Key). This does not affect User Macros. MIDI Show Control (MSC) can now trigger any Playback (see ZOS-1216). Showfiles using MSC should be tested in advance. If the received MSC message has a blank Q_List ID, ZerOS will trigger the currently viewed Playback and no longer always Playback 0. No other compatibility issues known from 7.13.2
  3. Thank you for your reply I looked a little more and I used the filters option. I did the research for my AFX light 1820IR and I tested some projectors that was offered to me. But nothing works For the cumulative library, this is probably not the case for me. Unless I have to perform a previous step to the update. But the AFX or ADJ brand no longer exists in the new version of the library. Once I have downloaded the new version (either 7.11 or 7.13 or 7.14) I download a show that I already had with version 7.9 In the library my spotlights are red, but nothing works Thank you for your feedback
  4. Bonjour Je possède une FLX S48 zéro88 (softwares version : 7.9.4.3) depuis l’année 2019. Elle fonctionne très bien et je n’ai jamais eu besoin d’effectuer de mise à jour. J’ai un plan de feu plus ou moins fixe avec un matériel qui ne change pas. Suite à des projecteurs lumières vieillissant, j’ai acheté des projecteurs lumière (Mac-Man - « Flat Par 18x12w 6in1), j’ai décidé de faire une mise à jour du logiciel et de la librairie de ma console dans l’espoir que les projecteur soit facile à installer. (software 7.14) Erreur de ma part, je me retrouve à ne plus pouvoir installer les 3/4 de mes lumière et je ne peux installer mes Mac-Man. Plus rien n’est dans la liste de la librairie. J’ai essayé de les créer par moi-même en me référent aux manuels des projecteurs et de la console. Mais je ne comprends pas les termes, ni les abréviations. Les termes dans les création des canaux ne correspondent pas à ce qu’il y a d’écrit dans les manuels. Bref rien ne marche. Je tiens à préciser que je n’ai pas de PC et que je peux donc utiliser fixture.tools.exe. Je possède seulement un macbook Je possède : AFX light 1820R en 12 canaux ADJ - ikon profile et aujourd’huihui des Mac-Man - « Flat Par 18x12w 6in1) Pouvez vous m’aider Pouvez vous m’expliquer pourquoi le matériels dans ma vieille librairie n’existe plus dans la nouvelle librairie. Existe un lien vers des créations de fixture faite par des utilisateurs de la console et qui sont téléchargeables Merci d’avance ——————————— Hello I own a FLX S48 zéro88 (software version: 7.9.4.3) since 2019. It works very well and I never needed to update. My hardware hasn’t changed since. Due to aging lights projectors, I bought light projectors (Mac-Man - “Flat Par 18x12w 6in1), I decided to update the software and library of my console in the hope that the projector would be easy to install. (software 7.14) Mistake on my part, I am unable to install the 3/4 of my light and I can not install my Mac-Man. Nothing is in the library anymore. I tried to create them myself by referring to the manuals of the projectors and console. But I don’t understand the terms, or the abbreviations. The terms in the channel creation do not match what is written in the manuals. In short, nothing works. I want to make it clear that I do not have a PC and I cannot use fixture tool.exe. I juste have a Macbook I have AFX light 1820R in 12 channels ADJ - ikon profile and today I have Mac-Man - «Flat By 18x12w 6in1" Can you help me Can you explain why the materials in my old library no longer exist in the new library. There is a link to fixture creations made by users of the console and that are downloadable Thank you in advance
