Charlie Newman
Everything posted by Charlie Newman
  1. Usually the command line goes red if you've entered invalid syntax, or tried to exceed the allowed parameters. Is something similar happening when you try to save and/or record? Have you attempted to hit "Clear" only once before saving so the command line is empty? Hope these help!
  2. Hi, really depends on the kit you've got in the venue. If it would be RDM compliant then maybe go for that (I haven't had great experiences with the FLX's), but otherwise reverse engineering may be the way to go. Is there no chance of getting to the rig?
  3. Ah perfect, thank you ! Forgot you could trigger cue stacks.
  4. Hi all, if I remember correctly you can create chases within cue stacks. If you can do this, how can one edit those? Need to have a repeated set of states, and a chase is unfortunately the best option (unless I'm missing something), as you can't trigger cue stacks from other cue stacks. Thank you in advance!
  5. Can't believe I didn't notice this haha, looks slightly different from what I remember 🤦‍♂️
  6. It's not on the Wayback machine unfortunately @Archie D, but here's the old link anyway: https://common.zero88.com/a-z Sorry I couldn't have been of more help.
  7. I've stayed away from it for now, but more recently I've noticed the desk will start freezing after about 4-6h of programming unless I restart it which isn't entirely ideal.
  8. I'll have a look when I get home (I fear I may have deleted my bookmark), but that's a good shout
  9. Hi all, from what I'm aware of (and the replies I've received), they don't seem to have any plans of getting the Android apps back on the appstore and for now are just sending the APKs out. I doubt we'll have any further updates to the apps at this rate.
  10. There used to be a huge archive page of Z88 products but seems like the Signify folks got rid of it - it only went down a few months ago. Real shame as it had a lot of great info including all the old desks...
  11. I've had no progress on any, might try giving them a ring...
  12. Hi Philh, having the same issue here. I've contacted Signify but I don't have the world of confidence in getting a reply unfortunately.
  13. Not entirely sure how I should open the log file to be honest haha, I assume I need to decrypt it somehow.
  14. Welp I had a major show crash with a Z88 LF96, managed to get some Linux errors. Sent them a showfile 19th March and no response... I'm not hopeful for the future.
  15. Ah ok gotcha, makes sense. Sorry wasn't trying to be hostile or anything just wanted to provide all the options
  16. I believe it can, just not with static IP mode?
  17. Others please do correct me if I'm wrong, but I can't see it making a difference depending on the protocol as they're both reliable unless something later down the line failed in which case a backup desk wouldn't solve the issue. So it shouldn't do as I can't see the desk failing exclusively with sACN.
  18. Yup, couldn't agree more. I guess the days of technical support here on the forum from official sources are done, hopefully we'll be shown otherwise.
  19. Wasn't expecting to see this, thank you for all of your support @Jon Hole, hopefully the other support reps will be able to match your knowledge and activity. I wish you all of the best in the future, you'll be sorely missed!
  20. Sure! Hopefully it lets me send these. These are both apps for android. ZerOS Monitor.apk ZerOS Remote.apk
  21. Did you want the APKs of them?
  22. Super excited to see the FLX S consoles becoming more viable alternative for main control surfaces rather than just as a backup to the FLX console. The features look great and I look forward to trying them out! Merry Christmas all!
  23. Ah man that's super annoying. Is there any ETA on having that done? I've currently just moved the files over to new devices. Is it possible to release an APK or similar in the meantime?
  24. Have the remote and monitor apps just been removed from the Play Store @Jon Hole, everything redirects as an error and I need them on a new device.
