noteningenieur
Everything posted by noteningenieur
  1. How is it possible to change the palette (colour) in a running playback (1 cue = submaster)? So far this is only possible in Chanel mode or when a group is selected. Thanks for helpful answers Martin Nehrig
  2. Hello Edward, yes, thank you very much - I have already replied by email. The error is fixed by downgrading the operating system from 7.14.2 back to 7.14. Unusual - but it now works without flickering. I still had to recreate 2 fixtures by hand because it didn't execute the prefabricated library fixtures correctly. Top - now everything works without errors. Many thanks for the quick help and the tips here. Martin Nehrig
  3. Hello Dawidmk, Thank you very much for your comprehensive and profound reply with many valuable tips. Tomorrow I'll get to the bottom of the problem and set up the console again from scratch and then add a new fixture step by step.
  4. The following problem is occurring with my new Zero88 FLXS48 console (2 DMX universes): One of the devices connected via DMX flashes briefly at irregular intervals. The error occurs regardless of which devices are connected, i.e. with conventional dimmer channels as well as with multi-channel devices (LED bars or moving heads). The error also occurs when all faders are set to 0. Wired is DMX. It is also terminated. RDM, ArtNet etc. are deactivated. The latest firmware is installed. If I connect another console via DMX (e.g. Strand 200 Plus), everything works perfectly. How can the error be rectified? Many thanks for quick help says Martin Nehrig
