BjDick
Everything posted by BjDick
  1. Another silly question from a newbie: Let's assume I have a playback which includes some dimmer channels only. It's straightforward to make the GO button enable those fixtures as long as being pressed ("Flash"). But can I make the playback to fade out the dimmer channels when I release the GO button? This seems to be easy when I enable the playback with the fader. However, when enabling it with the GO button (configured as "Flash") the dimmers seem to switch off instead of fade away. BTW: Is there a more detailed manual for ZerOS as that shipped for FLX S24? (so that I can look those things up in the manual instead of spaming the forum ;-)) Best & Thanks a lot! Björn
  2. Works great! Thanks a lot! 😊
  3. OK, that way I can do some kind of a submaster, i.e. by lowering the fader of Playback 2, I can reduce the brightness of _all_ the channels I recorded to Playback 2. Is it also possible to lower the brightness of that channels by pressing the GO button of Playback 2?
  4. Hi, I'm quite familiar with Chamsys MagicQ but new to ZerOS/FLX S24 and would like to do the following: * playback 1 controlling some (HTP) dimmer channels (trivial) * playback 2: Set some of the dimmer channels controlled by playback 1 to 0 (i.e. blacken them out) as long as I hold the flash button of playback 2. Is this possible? Best, Björn
