Les Green
Everything posted by Les Green
  1. All sorted now. Thanks for your help. I am a relative beginner and I didn’t know about LTP!
  2. I am having a problem on a Zero88 Solution XL desk. Trying to modify a stored playback. How do I change one of the programmed lanterns to a reduced output. I used to raise the relevant lantern fader to maximum then reduce it to the level I needed or zero to delete the lantern from the playback. Now I can only increase the level, not lower it. Any ideas?
  3. I have a playback programmed on a Zero 88 Solution XL. I can add an extra lantern by putting the fader up to the level I require then RECORD>MERGE. I can’t remove a lantern or reduce its intensity. I used to be able to do this by moving the requisite fader to maximum then reducing it to the required intensity or zero then RECORD>MERGE. I am guessing it is operator error rather than a desk problem. Any ideas?
