        discover
                Posts31
Everything posted by discover
	With FLX S24 Version 7.14 I had programmed an run a show using playback on faders, which has worked out fine. During the show for a special scene it became necessary to manually change the position and colour of the moving heads using the CHANNEL mode. Returning back to the PRESET mode, I could run/follow the next presets, but after the last preset, I could not get an complete blackout. The manual setting remainded. a) What is the easiest way to get a complete blackout in such a situation? b) Is there a better way to perform manual changes during a show using preset?
	Filenames (USB) Backspace [BS] erases filename completelydiscover replied to discover's topic in FLX S24 & FLX S48 Thanks - got it. May I suggest for a next firmware update that the file name is not highlighted/selected per default?
	Select, save just one feature ("slicing" a show)discover replied to discover's topic in FLX S24 & FLX S48 Thanks, I have successfully tested that and it works fine for me in this case 🙂 As an outlook: would it work with a Cue-List or not?
	With FLX S24 Version 7.14 For an upcoming show, I save show files after each rehearsal on the USB stick. As the FLX SD24 does not have a battery nor clock, I want to add date and time manually to the filename at the end of it: eg. Mermaid-2023.11.24-1800 Mermaid-2023.11.25-1900 If I press backspace [BS]: ...the whole file name gets erased: ...and I need to type the whole file name again. Is there an alternative to this?
	Select, save just one feature ("slicing" a show)discover replied to discover's topic in FLX S24 & FLX S48 Thanks, Edward a) Do y understand you right: "prepare" means in this case: moving them to the new postion without/before lighting up? b) If I "change the playback's flash button to be a Go button" will it just afect this single flash button? Here again, I want to be shure that these changes do not affect the whole concept of "slicing" a show.
	Select, save just one feature ("slicing" a show)discover replied to discover's topic in FLX S24 & FLX S48 Thanks, Edward As Kevin stated above, to leave SmartTag enabled: will this disabling refer to: - all Playbacks/Cues or - just this Playback/Cue?
	Select, save just one feature ("slicing" a show)discover replied to discover's topic in FLX S24 & FLX S48 Thanks; I think I got the most of it 🙂 I am preparing for an upcoming show with moving heads, now. If I playback CUE 4. color mix A CUE 5. color mix B it works as requested: the position remains with previous playback of CUE 1: moving light position A If i store e.g. CUE 1: moving light position A Has it to be stored necessarly with a intensity/light on (raised fader)? Background ot this question is: In a theatre show I might fade the lights of a current scene and with a next Cue/Playback, I want to move the moving heads "in the dark" ("blind") to their next position. - The audiance shall not see the movement of the moving lights at all.
	Thanks, Edward I have learned, followed your instructions and set-it up accordingly. This has worked out. 😀 My most important take-away of this post is to understand the modes and eg the limitatios of the simplier mode (in this case colour mixing). - In this case, I go for the higher mode (15 Channel) which makes life easier.
	Lock parts of the FLX S Desk for simple usersdiscover replied to discover's topic in FLX S24 & FLX S48 Thanks, Edward This is the solution. 😃
	We have programmed an FLX S with a few presets for a basic event hall. How can we lock parts of the FLX S Desk for simple users e.g. disabling them to enter the programming mode? Just playing cues/playbacks etc would be sufficient.
	Thanks. This is a (nice) download of the online documentation?
	Where can I find the complet PDF Manual for FLX S in english?
	After a firmware update you are asked to "switch off" FLX S. There is no switch button at FLX S. Does "switch off" mean disconnect the power cord?
	Just for my technical undersanding: why not? I assume, that FLX S has a or even the same computer inside like the FLX (?) too.
	How to set date and time with FLX S? I have just (22.07.2023) saved a show to the USB stick and file date is: 09.03.2018 - that is irritating.
	Select, save just one feature ("slicing" a show)discover replied to discover's topic in FLX S24 & FLX S48 Thanks, EdwardAnd yes, this is the 2nd part of my question (1. mix and save and 2. use/play back the "static" mix for shows with fixed scenes) 😃
