showguy
showguy last won the day on June 12 2024
showguy had the most liked content!
showguy's Achievements
  1. Weirdly enough I couldnt receive any ArtNet with DMXControl either. Either way, I've updated to the latest ZerOS and now everything works as expected. Thanks!
  2. Hi, Ive been having some trouble getting Art-Net running. I have enabled Art-Net under the Universe Section, and set my current universe. Im using Artnetominator to see if I receive Art-Net. However, I simply dont receive anything. Sending Art-Net from another PC in the same network (same router/switch) I receive Art-Net okay. The FLX S 24 gets an IP via DHCP from my Router, static wont work either, so its not an network issue. Connecting the console directly to my PC without any switch whatsoever wont work either. What am I missing?
  3. Thanks for the reply, this should do it.
  4. Hello, Is there any possibility to control single channels from the ZerOS Remote App? From reading online I can tell the Apple Watch App supports this, however the app on my android doesn't appear to. Am I missing something?
  5. Nice! From what I can see in the emulator, this seems to be working good. Ill try this on the stage in a few days. Perfect Thanks!
  6. So, I've done some more digging. As you know, I want the beams to move on dark, and then be able to slowly crank up the intensity. I've created a small video. I'm not running windows on my pc, thats why this video is on an laptop. Most details are on the screen, I didn't really wanna bother setting up Capture. Hope this helps. If this is not an bug, I would appreciate an explanation very much.
  7. @Jon Hole Having problems posting a reply... As I can post here, Im not sure why it fails...
  8. Hey, I'm trying to take advantage of the Move on Dark features. I have some led moving heads, and I want them to first move to position B, with 0% intensity, and then fade up with the fader. For that I've created an Stack of two cues, one with (unset) intensity and the correct position, one with 100% intensity. I've set the fader function to "Manual fade (1 way)", so far so good. It works. Now when I pull the fader down, the spots stay at their position, which makes sence. Ive figured that pressing Clear + fader button I can get them to move back to home. However then, the fader wont work at all. What am I doing wrong? Is there any better way to go about this? Having an automated fade is not really an option for me
