milon
milon's Achievements
  • Reacting Well Rare
  1. Thanks @Edward Z88 Email sent
  2. I rolled back to ZerOS7.12 and loaded the oldest showfile I have and it seems like it's working, but I don't trust it to continue to do so... And the bootingproblem is still a problem.
  3. Here is the show file Zero88 20230328 complete show NY.zos
  4. We had problems with booting our FLX so I upgraded to ZerOS 7.13. Still have problems with FLX not always booting correct, about every fifth time it just stands flashing the leds to every fader. When breaking power and trying again it often starts. But that is not the biggest problem right now, since we CAN make it start. The great problem is that suddenly the FLX just freezes, all connections with all fixtures are lost and no buttons are working. I tried to delete the show file and loaded it again and the time till it froze again was a bit longer (20 min instead of 4 min, approx) but the problem is not solved. What can I do? It's quite acute to fix the problem so please help.
  5. Problem solved! When I was about to change to 5-pin xlr I saw that 3-pin was output 2 and not 1. Why this adjustment didn´t come along with the rest i Showfile is a mystery but now everything is working as before. Thanks!
  6. DMX-adresses are as expected and are matching the fixtures. I only have one Universe and it's enabled, and DMX is enabled in Setup. The values are changing in Output window when I raise and lower masters. It´s like the DMX-cable isn't connected, but it is. I my fixture schedule everything in the column "Fixtures/Modes" is pink/red. If i change Fixture Type the new Type is in white but Fixture still does not work. I'm attaching both .isf file which I created before update and .zos file I created after update and after I loaded the .isf file. (The .isf file was what Save Complete Show rended before update Zero88 20230328 complete show.isf Zero88 20230328 complete show.zos
  7. After I updated our FLX S48 to 7.13 and then loaded our saved Complete Show file I can see I have all fixtures in the schedule that I assigned before, but I don't have any connection to my fixtures. Nothing at all happens when I use the submasters. I tried and saved Complete show again and the I saw the new file is .zos and the older ones are .isf. i tried to load both of the files but it doesn't work. I have checked the dmx-cable over and over again and it's connected. I tried to delete one fixture and added it again and it still doesn't work. I restarted FLX after loading Complete Show file, that did not help. The lamps blink like when FLX is off, like they are not connected. What am I missing?
