Zebroid66
Zebroid66 last won the day on September 6 2023
Zebroid66 had the most liked content!
Zebroid66's Achievements
  • Dedicated Rare
  1. Hello. Could you please advise me on the model of potentiometers used on submasters? I need to replace a couple of submasters due to them malfunctioning.
  2. This is an Elation Wi-Fi transceiver. I connected the DMX cable directly to the device, and it worked correctly. So, I identified that the issue is with the transmitter. However, today, I was thinking about how to solve it because the transmitter only allows changing Wi-Fi signal transmission addresses. But changing the addresses didn't help. Completely by chance, I found this error on the fixtures. In the "Edit Fixtures" section, I reloaded the fixture file from the library, and everything started working. By the way, in firmware ZerOS Version 7.13.2, I have a bug where the indicator for the fader page keeps flashing all the time.
  3. I found the problem, and it lies in my Wi-Fi signal transmitter.
  4. i use elation fuze wash z350, all of are patched in screenshot files here https://www.dropbox.com/scl/fo/re8db33mdrhel5mtgzvjn/h?rlkey=h7tdok73o04ooaxfkl9sfa4v6&dl=0
  5. Hello! Today, I encountered an issue when adding devices. I have 4 universes on Solution XL. Universes 1 and 2 are already in use and working fine. I added new devices to universe 3, and the situation is that I have a limit of 100 addresses (100 dmx adress not working. For example 80 adress working fine). The same issue occurred with universe 4. Universes 1 and 2 have all 512 addresses in use. The firmware is up to date for last version
  6. Hello! Can you help me with a fixture profile of a Elation FUZE WASH Z350 for 15 channels https://www.elationlighting.com/fuze-wash-z350 I found fixture file in topic, but it doesn't suit me because it for 19 channels. I need 15 channel fixture profile
  7. 1. This is 1st time for use. 2. No, i don't update Android for 12 vers. I consider that the application should support previous versions of Androids. 3. I use version Zeros 7.8.2.39. I already assume that you will offer me to update the firmware of Zero Remote. I test it and i don't like new "square" interface of submasters on monitor. This is not very informative for me. I am satisfied with the inline design of submasters. It very cool to read the text on the submaster's display in capital letters. in the new version they are also not comfortable to read, because they are very small It would be great if there was an option to customize things like that in new firmware
  8. Hello! Can someone explain what happend with andriod app ZeroOS & Zero Remote ? I can connect on my laptop throw WiFi to my Zero88 with ZerOS (Monitor) and it is work correct. But mobile application doesn't working with it. I realy need use it throw mobile. I use Moto G100 and android 11. Please help me to solve a problem
