RichardNR3
Everything posted by RichardNR3
  1. Trying to upgrade from 7.13 All goes OK, I then load a show file and, although it seems to go OK, no fixtures work although they seem to be receiving a signal. Revert to 7.13 and load the show file and fixtures work OK Tried this a number of times using various show files but no progress. Also tried re-downloading 7.14 Is factory reset my next option?
  2. Tried changing the trigger level but had no effect. 🤔
  3. Very simplistic - we only have two LED Fresnels and the rest are generics. Also I am quite new to the FLX. Have never used tracking or move on dark! Running on subs - so even if I have only two faders programmed - one for each LED - then just bringing up the light will still have the delay.
  4. What am I doing wrong? I have a LED which comes up on its default colour before going to the desired green. The same happens on other channels. I have tried deleting and recreating to no avail. Up, down and colour times are set to zero. What am I missing?
  5. If I the same LED lamp on two playbacks - using one with it set to red and the other to blue- If I cross fade between the two the colour transition jumps - is there anyway way of smoothing it? Sorry if this is a beginners question.
