Mark-Jazzie
About Mark-Jazzie
  • Birthday 10/12/1971
Mark-Jazzie's Achievements
Newbie
Newbie (1/14)
  1. Hi. I am very new to the forum pages but have worked with and installed zero 88 lighting systems and control platforms for many years. I really enjoy using Zeros and the FLX range of consoles and as the name suggests they are very flexible and easy to work with. One feature I would like to see on Zeros Is the Universe Map or Universe Preview as described when adding a fixture, after you have added all your fixtures. Unless I am missing a big trick here or that special key tap I have not found, if I need to change the address of a fixture which does sometime happen either changing of rig set up or just made a mistake, either I have to calculate the address needed myself or add a false fixture just to see the universe space available. Yes, I now you have the DMX Output Screen on the "Z" Button, that only show you the output levels that each DMX Channel is at a specific time. Also I know you have the likes of RigSync but this sometimes is not practical or can not be used. I know that this feature may not be a priority for some or what the cost and complications to implement this feature would be. I do think that it this would be a valuable and useful tool to be able to use. Either when selecting an address or the address column in the Fixture Schedule and may be as the system info on the "Z" Button Your thoughts please Mark -Jazzie
