Ed75
Everything posted by Ed75
  1. It seems since my upgrade to 7.13 the "programmer time" function doesn't work anymore? it keeps 'snapping' instead of using the amount of time I put on the wheel. Both on FLXS as on the Solution. Tomorrow I 'll start pre-programming a tour, which should really be up and running coming saturday. (last minute job) I guess I will be correcting and busking at least the first show. Would be very nice if the programmer time works.
  2. I just connected the FLXS . works fine. Also running 7.13 (the same version as on the Solution)
  3. Hi Edward, I do not see these options. I connect via ethernet, on a windows 10 laptop. Which setup worked flawlessly with my FLXS . (before I installed the last version of Zeros monitor it did) I have to check if it still works now. I hope I have time for this today.
  4. Thank you. Not at the desk at the moment, (and the rest of the day) I guess it's the latest version . I downloaded it together with 7.13 lately. The desk runs 7.13.
  5. Hi all, It seems Zeros monitor doesn't work on my Solution. I can connect to the desk, after that I get the black Zeros screen, but it doesn't give me the option menu which screen to show. Any idea's?
  6. Thanks! Yes of course this is the way of doing it now. I was just curious, because it would be a very fast and convenient way of changing values fast in more than one cue.
  7. Thank for your answer! I am really looking forward to this!!
  8. Ah, yes I have seen this option. Thanks for your answer as always ! As I understand there is no way of selecting cues (for example cue 5 , 17, 21 , 45 ) and changing one value in those?
  9. Hi all, is there any idea about the adding of OSC-functionality? (via network) am really waiting for this. right now I am still forced to use a laptop with lighting software with every show I need this. Despite having two zero88 lighting desks running the newest software..........all very nice , but I think osc functionality is nowadays sort of basic need....... I am doing quite a lot of (smaller) shows which would fit a FLXS perfectly, but I can not use it, because of this lack of OSC functionality. It is really a pity I have to solve this by using a laptop for lighting.....
  10. Yes, I am aware of this, I just wondered if one could change values (of the same attribute) in more than one cue at once. I used to work with some lighting-sofware on a laptop which had this possibility in the "track sheet" . can be very convenient. If this is not possible I do not expect this to be changed, given the fact it is only an "outdated" Solution/Orb feature
  11. Hi all, Managed to get my hands on a very reasonably priced near mint Solution. So at the moment I am discovering it, together with the possibilties of the Zeros software on it. Last months I was too busy to get to updating my FLXS, so I updated both desks now to 7.13. Both seem to work fine, and on the Solution I am discovering the handy things I sometimes miss on the FLXS. The FLXS has flawlessly run a pretty big theatre show for it, last september/october, (10 "complicated" movers, of 2 different types, 10 LED wash movers, of 2 different types and about 32 dimmers) . The programming for this was mostly "on the fly" during rehearsals, and countless times I've done the "update-GO" action almost immediately followed by a "GO" for the next cue to appear. The FLXS never stopped , crashed or hiccuped or whatever. This included triggering effect playbacks and so on. Great! But Yes, programming could have been easier on an fullsize. (FLX or Solution) Now I finally found one nice Solution. Going through it, and trying to find everything, I found the "Fixture levels window" Is this only a Solution thing? or also on the FLX? Couldn't really find the answer in the manual or this forum. Is there any possibility of selecting several cues and editing a value in all these cues at once? Like sort of spreadsheet behaviour? I couldn't find it, and maybe this is not possible, would be a nice feature. I can imagine it is not possible because of tracking-issues?
  12. Thank you both for your answers. I knew the key features of the Solution , after reading all info, only some things which are not directly mentioned in the zeros or the solution manual were not clear to me. I just wondered if you have put some software-limitations into the Solution software, like on the FLX S range. And of course I am aware of the wing possibility, but being honest I think it's slightly overpriced so to say....... which brings the step of buying a complete (used) desk a bit closer. A) sometimes it is handy to have an extra desk B ) it gives me backup possibilities.
  13. Thanks Jon, I was wrong indeed. it got a bit late programming.... The method you mentioned works flawless.
  14. After having a quick glance through this manual : I understand the preset faders (in channel mode) are only assignable to 1-address fixtures? (eg dimmers) ? Multi-channel fixtures need to be patched to the mfk's? or is this changed during some updates of zeros? The reason for these questions is I might consider searching for a Solution, because there is no need to switch pages then, between channel and playback mode, because of the seperate playbacks. Which is a little pain for me on the FLX range
  15. I'm pointing at this 'licence' limitation indeed. I can imagine (but I hope not) there will be some issues about the processing power etc. Thanks for the link tot the manual, didn't find it yet. I'll dig into it.
  16. I was pretty sure. But I might be wrong of course. I'll try later today! Thanks!!
  17. Can someone tell me which functionality zeros has on a Solution desk? The same full-functionality as on a FLX ? Or some software limits like on the FLX S desks? I have been searching the zero88 site and manuals and this forum for more than an hour now, but couldn't find any exact answers on this.
  18. Hi All, if I type a cue number in the command line and press "go" it will go there.......except for three digit numbers. example: "16" will work fine, "161" won't. FLXS 48.
  19. Let's hope this clears things up for Techie_v2 then .
  20. You're right I'm sorry about the 'snap' idea. But it WILL go play the effect then from the positions of the copied cue ?
  21. I didn't have the opportunty to try. The question what happens if between cue 1 and 2 are several more cues is the other question indeed. I think If there is position data stored in cue 1 and you copy it to cue 2 (with other cues in between) it will probably snap the lights to the position of cue 1 and play the effect from there.
  22. Ed75
    Stopping effects
    I think this is the way indeed. You could make this cue an autofollow of course.
  23. Just double-tap a group so it comes on, and record it on the fader you wish?? Or am I thinking too simple ?
  24. Thank you. I had been reading all the information from your link already. Before posting this topic on here. Thanks!! I will consider all this.
  25. Ok. Thanks as always for your fast reply . Is there anywhere in the online documentation where I can find the limitations ? Couldn't find it 😉
