Hi,
Not sure if this has already been reported...
I noticed a bug with the FLX-S48 console (7.13 version), and probably with other FLX consoles :
In fader functions, when I select "manual fade (one-way)" or manual fade (two-way)" the new parameter works fine, but when I try to revert back to its initial state ("HTP master" for example), the behavior remains as it is, and doesn't go back.
The only way I found to change the setting again is to turn the console off and on.
The same is happening with phantom zeros 7.13 running on my PC.
maybe this will be fixed in the next update 🤞
best regards
Pascal S.
