Hello there,
I have been using the FLX S48 for almost two years now.
The experience is very positive until now, and as I can see there have been some major improvements by the team.
I would like to address an "issue" I am facing, and ask if there's a practical solution to this, or we shall wait until the next update.
Whenever it comes into creating an effect, some times I need to "split" the effects direction throughout my selected fixtures in order to achieve a "mirrored" effect.
As I can see, this can be achieved by selecting let's say the first half of my fixtures and set a positive value of speed using my encoder wheel and then select the second half and enter a negative value (ex. 1st half at speed: 18 / 2nd half at speed: -18).
The main issue is that I rarely can get the same number in positive / negative values.
Most of the times I can get even positive numbers, but when it comes to the negative, I mostly get odd numbers.
Also, by moving the encoder wheel, the value jumps two by two values (18, 20, 22, 24 / -19, -21, -23, -25) and makes it hard hit the desired value.
I would love to know if there's a simple solution to this. Furthermore, I would suggest that in the future we 'll be able to enter the speed, size & offset value manually, using the virtual keypad, which currently happens when it comes to fade timing whenever I am editing a cuelist, if I tap on fade time. (keypad pops up)
I attach everything I mentioned above in pictures.
Looking forward for your answer.
Kind Regards,
Dimitri
