decnicolaou
decnicolaou's Achievements
Newbie
Newbie (1/14)
  1. Dear Edward, You 're a lifesaver once again! Thanks for the support and the very quick and detailed reply! All the best, D.
  2. Hello there, I have been using the FLX S48 for almost two years now. The experience is very positive until now, and as I can see there have been some major improvements by the team. I would like to address an "issue" I am facing, and ask if there's a practical solution to this, or we shall wait until the next update. Whenever it comes into creating an effect, some times I need to "split" the effects direction throughout my selected fixtures in order to achieve a "mirrored" effect. As I can see, this can be achieved by selecting let's say the first half of my fixtures and set a positive value of speed using my encoder wheel and then select the second half and enter a negative value (ex. 1st half at speed: 18 / 2nd half at speed: -18). The main issue is that I rarely can get the same number in positive / negative values. Most of the times I can get even positive numbers, but when it comes to the negative, I mostly get odd numbers. Also, by moving the encoder wheel, the value jumps two by two values (18, 20, 22, 24 / -19, -21, -23, -25) and makes it hard hit the desired value. I would love to know if there's a simple solution to this. Furthermore, I would suggest that in the future we 'll be able to enter the speed, size & offset value manually, using the virtual keypad, which currently happens when it comes to fade timing whenever I am editing a cuelist, if I tap on fade time. (keypad pops up) I attach everything I mentioned above in pictures. Looking forward for your answer. Kind Regards, Dimitri
