kinous
Everything posted by kinous
  1. Hi Edward. With this update the problem seems to be solved. Everything is ok. Thanks a lot!!!
  2. Hi. I checked twice it matches. I also tried to swap or invert but I still have the same problem.
  3. Hi. I've just added those two fixtures on my console. No problem with the Varytec. But with the B1R there is a bug on the position menu. When I turn the pan wheel it moves correctly but the tilt is also moving back and forth at the same time. When I turn the pan wheel it moves from 1 cm back and forth only.
  4. Thank you very much Edward.
  5. Here is the link to the manual of the Varytec's fixture https://images.static-thomann.de/pics//atg/atgdata/document/manual/451167_c_451167_481687_v4_en_online.pdf
  6. No problem it wasn't urgent. I've followed the link below "option 3 request" in May the 14th. It was the same adress you forwarded my fixture request to. By the way I can't attach the Varytec fixture's manual. The file is 1.1mb. Do you have another option to send it to you? Thank you for your help.
  7. Hi. I've sent you an email a few month ago about creating new fixtures but didn't received any answer. I've bought 8 stairville B1R moving head and 8 Varyec Hero Wash 715 HEX led. Unfortunately they are not in the library even after the 7.9.9. upload. Can you please create those fixtures for me? I'm totally unable to do it. You will find the manual attached on my message. Thank you for your help. Stairville B1R manual.pdf
  8. Hi.
  9. Thanks a lot I appreciate it
  10. I think the Asteroid supports RDM. I'll try to connect it to the 5pins dmx plug to see if it can be automatically linked to FLX. You're right I see neither hero spot 60 nor hero wash 715 HEX. I'm not skilled enough to create my own fixture, I will follow your advice and ask for help I think. Because of covid 19, most of shows are canceled in France, clubs are still closed... I do have time to practice and upgrade my knowledge.
  11. It's to control an ADJ Asteroid 1200. I'm using it as a centerpiece. I also have 8 varytec hero wash, 8 varytec hero spot60 and 8 adj Par Mega hex RGBWA +UV. I just received my FLX S24 today, but I'm not sure to have time to have a look on before friday. Anyway be sure I will ask for your help. Thanks again.
  12. Great!! Thanks for your answer. FLX S24 1U will be enough for me 🙂
  13. Thanks!! Without wing?
  14. Can the FLX24s control a 64 channel fixture?
