Opps now I have an update. I just successfully installed the update 7.9.7 version into my USB, which mean the problem in the previous post had been solved. Yet after I plugged in the USB into the console, I cannot see any software update application during the power up of the console. Which mean the version is still staying in 7.8.1.2. I have tried several times to reboot it but nothing changed. Is there something I missed causing the fail of installation?
- Download the USB Install Creator application available from the latest ZerOS Download (done)
- Extract/unzip (done)
- Run the ZerOS OS Creator USB (Done)
- Insert a USB Memory Stick into your Windows PC when prompted and follow the on screen instructions of the ZerOS OS Creator. After a few minutes, the install creator will instruct you to remove the USB Memory Stick, which now contains the update for the desk. (done)
- Remove the USB Memory Stick from your PC and insert it in one of the desks USB ports (Done)
- Power on the desk and the desk will automatically boot into the software update application. It is recommended that you have a monitor, keyboard and mouse connected to the desk to perform this update. (Not yet done)
- Press the [Install ZerOS] button on the monitor and the software will be installed (Not yet done)
- Once the update is complete, you will be taken back to the "Install" screen (Not yet done)
- Switch the console off, and remove the USB Memory Stick(Not yet Done)
- Reboot the console, and you will boot into the newly installed software (Not yet done)
