sossy
Everything posted by sossy
  1. Thanks this makes it way easier to find all my playbacks
  2. is it possible on FLX S24 or S42 to name playback channels individually ? if there is a possibility to do that i would be happy if you let me know Jakob
  3. It worked thanks alot
  4. Thanks i will try this soon and give you feedback if it worked or not Jakob
  5. Hello, I use the Showtec Phantom 70 Beam RGBW and I used the Fly In effect and when I'm in channel mode the effect is normal but when I press record and put it on a playback channel the effect is not the same as it was when I adjust it in channel mode. Is here someone with an similar problem or someone with a solution for my problem many thanks Jakpb
