sossy
sossy's Achievements
  1. Thanks this makes it way easier to find all my playbacks
  2. is it possible on FLX S24 or S42 to name playback channels individually ? if there is a possibility to do that i would be happy if you let me know Jakob
  3. It worked thanks alot
  4. Thanks i will try this soon and give you feedback if it worked or not Jakob
  5. Hello, I use the Showtec Phantom 70 Beam RGBW and I used the Fly In effect and when I'm in channel mode the effect is normal but when I press record and put it on a playback channel the effect is not the same as it was when I adjust it in channel mode. Is here someone with an similar problem or someone with a solution for my problem many thanks Jakpb
