slobelix
slobelix's Achievements
  1. Ok it was a polarity problem. Thank you very much for your help :)
  2. Thank you for your reply. I also thought of polarity reversal when I wrote to you in my last message. I will take a DMX 3 point and reverse the polarities it will be easier than opening the dimmer for now because it is used to light the room and when I am there there is always someone so it is impossible to cut the power . I'll keep you informed.
  3. Yes, this is it. Normally there is nothing problematic because it is quite simple. I followed Eric's recommendations regarding the Rigsync that I deactivated. I tried the addresses from 1 to 512 nothing responds. The data light on the Anytronic dimmer does not turn on when I plug in the FLX so there is no communication. When I plug in a very simple console (showtech sc 2412) it works ... I tried plugging the FLX on RVE Cube dimmer and it works. I think the problem is with the Anytronic dimmer. Yes the terminated DMX is at the dimmer.
  4. Hi Eric, Thank your for you reply. Indeed by updating the software it s already more complete However, I still have no control over conventional lights. I connected another dimmer with projector on my FLX S and ... It works. I think i have more than to test all the inputs of the dimmer to see if the spotlights are in 1-24 or not. I only see that as the problem.
  5. thank you for your reply. Unfortunately I already checked your recommendation and it did not work. I only have one universe, when I patch leds everything is fine. When I plug in the conventional dmx in another console it works too.
  6. Hi and happy new year, I have a FLX S24 light consol. I would like to control my conventional projectors which are themselves connected to a dimmer ( an anytronic contractor 24). I do "add fixture"→"generic fixture"→"dimmer" I enter my dmx addresses from 1 to 24 I validate and nothing happens. However the projectors work on my old showtech sl 24 12 and i have no problem for patching the led on the flx s24. Someone would have any idea ? Thank
