Chris Mower
Everything posted by Chris Mower
Problems with the Wizard in the Fixture Editor
Chris Mower replied to Chris Mower's topic in General Discussion
Thanks for the feedback everyone. Most helpful in that it saves me chasing my tail trying to get the wizard to work. Chris -
I have been having issues trying to add a special fixture where the editor behaves erratically. I have run it under Windows 10 and Windows 7 and get the same behaviour. There are two main problems that I am seeing. 1. When using the wizard to enter the details of a channel, after entering a couple of channels, say Pan and Tilt, and then after entering another channel it goes back to showing the Pan and Tilt channels again and you have to press enter to skip through them before you can add another channel. This continues for each new channel but usually misses some of the previously entered channels the next time. 2. After finally entering all of the channel details and pressing the finish you find that the fixture has lost most of the channels that were entered with just a couple of them showing after 8 were entered. I have tried several times with differing results each time but have mostly had a failure. Has anyone seen this problem? I am running the latest version of the fixture editor from the website. Also not a bug but a 'would be nice to have' while entering the colour channel property there was Red, Green, Blue and several other shades like Cyan and Magenta but not White. Could white be added as many LED Par's have White LED's as well Thanks Chris
I’m amazed at the quality of the Frog 2 desk Ian. The one I purchased on eBay looks almost unused with, apart from one tiny scratch, no signs of wear. I bought it as a cheap way to get up to speed with the Zero 88 desk having been using Strand mostly but more recently having to work with a Frog desk. It was odd at first but I have really got to like the desk and Zeros. In fact the more I use it the more impressed I am with the usability.
Yes, that was the problem. Working 100% again thanks guys. I must say that Zero 88 support is outstanding, especially for equipment that is way way out of production. Regards Chris
That sounds promising. Can you give me instructions on the correct procedure for opening the Frog 2 please? Chris
Edward Just sent you an email. Thanks, Chris
I wanted to add a fixture to the list so I used the Fixture Editor to create the file ( See attached LIXDA1.ift ). It is for a simple LED PAR by LIXDA and consisted of just the RGBW and the brightness channels, although it is somewhat unusual in that the channels of interest start at CH4 and skip the first 3. I imported the file into the desk which did not give an error then I added the fixture and went to test the functionality and found that the dimmer control, along with the Blue and Green channels would respond to the control wheel but the Red and White channels remained on 0. In case I had made the file incorrectly I re-made and re-imported after resetting the desk and clearing all, but this had the same result. It was then that I noticed that the center wheel was not now working on any of the fixtures even after the desk was reset and cleared when a known and previously good fixture was imported. I went into the Event Monitor which showed that wheel 0 and wheel 2 were showing events but wheel 1 showed nothing when moved. Is there a possibility of an .ift file causing a program glitch such that the wheel event would fail? It seems odd that a system that had never shown any sign of failure should fail at the exact same time as a file was imported. If so can this be fixed by re-installing the operating system, and if not how difficult would it be to fix the hardware? Thanks, Chris LIXDA1.ift
Thanks Edward, that solves the issue. Thanks for the assistance. Regards Cris
Further to the above I noticed that on the Desktop buttons there is one marked Programming on it but when pressed it brings up the Panel window. I have attached pics.
Edward don’t you guys ever take a day off 😃 The Program Window option is not present. I have attached a picture. cheers Chris
Edward Thanks for such a quick response, I hadn’t expected it on New Years Eve! You guys are good. I have attached three pictures. The first shows the display on screen one, which was blank as I had closed down all screens on both displays. The next shows the display after pressing the Program Window button on the LCD, which is shown in the third picture. Does this help? regards Chris oh, and Happy New Year to you all at Zero88!
Been going through the Operating Manual and have hit upon an issue. On the Frog2 LCD when I press the Program Window button on the screen the window that appears on monitor one is the Fixtures window. The button is pressing, and even makes a click, but it only displays the fixture window. Am I doing something wrong, or have misread? any help appreciated chris running 27.8.2.39
I suspected as much. Thanks for the help though, much appreciated. chris
Thanks Edward that is very useful. I have discovered how to assign the dmx channels to UDF’s so I can duplicate the methodology I normally use. By patching fixtures 1 to 48 as dimmers in universe 1 and then assigning fixtures 1 to 48 to UDF1 to 48 I can now set up the lights in the same way I usually do. The movers I have put in universe 2 and so far that seems to be working just fine also. One thing that I’m not sure about though, Is there a quicker way to assign the fixtures to the UDF without having to do each one separately? Sort of 1 THRU 48 RECORD UDF 1 and have it automatically save the rest? chris
Thanks Edward. I have the manual and the latest Frog2 O/S and although there seem to be a few bugs it seems to basically work OK. What I find is that although the manual seems to cover the topics it sort of assumes you are steeped in the way of the Zero88 methodology. What I was hoping to find was a sort of set of work-flow examples. Take for example the theatres that I have run lights in, which for the most part have been Strand or similar desks, universe 1 has simple dimmer packs on the first 48 channels and universe 2 has the multicolour LED's. Each of the standard fixtures is mapped to the a fader so to set up a scene you simply adjust the faders and then record the cue. I'm sure that this must be possible on the Frog2 but I don't seem to be able to find a way to do it. I hev managed to program cues and have even got moving head and multi-color LED's programmed as cues, but often I struggle to remember just how I managed to do it. I am gradually getting to grips with the desk, and as I said before I'm pretty sure that once I get the hang of it I will really get to like it. It's just that the learning curve seems quite steep at the moment. Chris
I have been trying to locate a resource for learning ZerOs but without much success. I have downloaded the manuals and have made some progress but it’s hard going as they don’t really start with the fundamentals of how ZerOs works. My background is in amateur theatre and I previously always used Strand desks, so Zero88 desks seem completely alien. I have used them on a couple of shows and although they were hard going I managed to program them, but never felt at ease because of the lack of basic understanding. However, what I saw of the desks intrigued me and I did feel that if I could get a good understanding of the fundamentals then I’m pretty sure I would really like them. To that end I bought a second hand Frog2 on eBay and have made a start. So I guess my question boils down to Is there a book or dvd or whathaveyou that teaches ZerOs for beginners?
