Hi Edward, perhaps I should explain a little more.
there are no other playbacks playing.
the dimmer is on 35% but it is on 35 % on all cues.
I try to correct this:
I call up a cue lets say cue 1,
the dimmer should be off, so I correct the channel to be off and then update cue 1 using the Z button (like explained in the manual)
if I then press clear and recall cue 1 the dimmer is on 35% again.
in other words: whatever adjustment I make, it does not record or update in any cue. It remains at 35% untill I manually pull down the channel-fader.
if however I try to edit a cue, lets say I change a LED-fixture from red to green and then update using the same method it records or updates that just fine.
any suggestions?
kind regards,
Steven
