Steven Gerrits
Steven Gerrits's Achievements
Newbie
Newbie (1/14)
  1. Hi Edward, I have found that after a long programming session (about 100 cues) the error started to occur. after I rebooted the table the cue's seemed to be fine. (updated as well) thank you for your help. Kind regards, Steven
  2. Hi Edward, perhaps I should explain a little more. there are no other playbacks playing. the dimmer is on 35% but it is on 35 % on all cues. I try to correct this: I call up a cue lets say cue 1, the dimmer should be off, so I correct the channel to be off and then update cue 1 using the Z button (like explained in the manual) if I then press clear and recall cue 1 the dimmer is on 35% again. in other words: whatever adjustment I make, it does not record or update in any cue. It remains at 35% untill I manually pull down the channel-fader. if however I try to edit a cue, lets say I change a LED-fixture from red to green and then update using the same method it records or updates that just fine. any suggestions? kind regards, Steven
  3. Hello everyone, I'm new to the zero series, however I have programmed a show with some 70 cues. on a FLX S24 everything works fine except for 1 generic dimmer channel that will not be recorded in the cues. I can manualy pull it down on the channel-fader, but it refuses to be recorded or updated in the cues. I am using a generic dimmer channel, wich should work because I can use it manually. perhaps there is some setting I need to set...? Help! kind regards, Steven
