Takuya Chinen
Takuya Chinen's Achievements
Newbie
Newbie (1/14)
  1. Hello, I have FLX full board and FLX-S48. I have tried to up to date ZerOS 7.12 from 7.11 before up to date to 7.13 the latest version. However, on both console, I have followed the instruction and the monitor showed that turned them off and tried to reboot them. However, The monitors are blacked out and they are not reboot. On FLX S48 keeps flashing the LED of MFFs buttons and LED of the page number keeps circling on FLX full board. I have tried to launch test mode and follow the rebooting process on the manual but, it does not work on both console. Does my process of up to dating have some problems? How could I fix and up to date to ZeroOS 7.13 successfully? Takuya
  2. Hi, Edward Smith Thank you for your early replying. I would send you an email attached the picture of my serial number.
  3. Hi, I have problem with MMFs for controlling intensity and running cue. When I raise Faders in either Channel mode or Playback mode, some of them are not work and internal display does not indicate any intensity levels. I have also checked “DMX outputs” tab on “System Information” page and DMX signals have not out from the Universe. This issue have occurred every time after powering on the console. Furthermore, these faders with the issue would change to the others every time I turn on the console, so I cannot detect specific faders with the issue. Sometimes half of the faders would not work. This issued has been occurred when I updated ZEROS to 7.10, but the console have been stable after updating to 7.11 last April. However, this issue has happened again. Does anybody have same kind of problem? Is this problem with firmware or hardware?
  4. Hi @kgallen and @iank99 Thank you for all your suggestion and support. I have been working on repairing my S48. I emailed support@zero88.com and now the console is able to reboot and worked fine! @Edward Z88 I appreciate all your help!
  5. Hi, I have exactly the same issue on my S48. I have tried launching ZerOS Startup Tool to plug my keyboards, but it does not work. I have tried using 3 different keyboards but, they do not work. I tried plugging for each of them to both USB ports of the front and back panels. However, still not. Do you have any tips?
