Bubbagump
Bubbagump's Achievements
  1. Hi, is it possible to park a fixture, similar to the FLX function using a UDK? Thanks Sebastian
  2. Thanks for the clarification Edward. I just figured that the S24 with an additional wing will give you the same amount of faders as on the S48. Given that the processor is the same (and therefore capable of the 96 fixtures), I don't really see any reason why the console should not be able to extend the fixture cound to 96 by adding the wing. This would be a really neat option: giving you the flexiblitiy to use the small S24 for smaller shows and optionally popping in the extension wing in case you are running the full rig for fixtures 49 thru 96. Guess the S24 is out of the game then. Again, thanks for your explanations. Cheers
  3. Thanks for the quick replies! Just wondering whether that limitation is coming from reduced hardware specs or purely a software inhibition. If it's the latter, that would also be something potentially to be removed via a payable upgrade, similar to the universe count...
  4. Hi all, I am currently thinking about purchasing a new console and would like to clarify on the decision between S24 plus an additionnal wing versus a S48 because the number of fixtures I am using is at or around 48. I understand the S24 can be later upgraded to a second universe, so the number of dmx channels will not be an issue. Adding a wing to the S24 will give me the option to cope with insufficient number of faders. But I am not sure whether any of those upgrades will remove the 48 fixture barrier. Any insights on this? Thanks Seb
