kraftfeld
Everything posted by kraftfeld
  1. thanks. worked with "inhibit". >> because i only have multiple other playbacks(=cue-stacks) triggered simultanously in the cues of playback1, fader1 doesn't behave as intensity-fader in my case.
  2. hi. i am trying do do the following on FLXS24, any possibilities?: > playback1 containing cuestack with a series of movement-effects and fader-effects of fixture-group. > playback2-fader controls maximum-brightness of fader-effects on cue1. from 0-255. >> i want fixture to always fade to black and then fade to maximum-brightness defined by playback2-fader. >> so maximum-brightness of cue can be adjusted. >> using grand-master-fader is not an option here, because i want to be able to adjust several fixture-groups separately, but function of grand-master seems to be what i need. >> i am also confused on how the size-parameter of fader-effect cooperates with intensity-level of fixture. do i set intensity to 0 and adjust final-brightness with size-parameter? or whats best practice here? thanks for help. thanks for the FLXS24. julian
