RaffaABC
Everything posted by RaffaABC
  1. Already sent Hope they can help!! Cheers
  2. Just found the manual. Please tell me it works!! https://www.dj-store.ru/data/files/files/280_file.pdf
  3. Yes, that's rigtht Keith replied to me. But it didn't work And the manual that it came with the product doesn show any more information about the lights. Don't know what 2 do now..!! But thanks alot
  4. Thank you Edward Here is the Tech Specifications that are on the Manual. Product name: 7R beam 230W beam moving head Power supply: AC90-240V, 50/60HZ LIGHT SOURCE: Ipcs 230W Light bulb FUSE: 7A DMX CHANNELS: 16CH COLOR: 14COLORS-WHITE PATTERN PLATE: 14PATTERN +WHITE MODELS STROBE: 0-10TOMES/SEC,ADJUSTABLE SPEED X-AXIS: 540'' Y-AXIS: 270'' LCD: ON/OFF PRISM: 8-FACET PRISM (16-FACET PRISM FOR CHOICE) FOCUS: ELECTRONIC LINEAR FOCUS FOST: WITH FOST EFFECT OPERATING MODE: DMX512, SOUND ACTIVED, AUTO, MASTER/SLAVE BEAM ANGLE: 3, 8'' N. W: 17.5 G, W: 18, 96
  5. Can someone help me to create a fixture for this type of lights .. PLEASE!!! https://www.amazon.com/Ridgeyard-Touch-Screen-Moving-DMX512/dp/B071KNQTL6/ref=sr_1_47?keywords=led+head+moving+light&qid=1565618648&s=gateway&sr=8-47 This are the specifications Specifications:Rated power: 300wVoltage: AC110v, 60HZColor: 14 colors + whiteStrobe: 0-12 times / secondReverse: horizontal / verticalDmx 512 channel: 16ch / 20chDimmer: 0-100% linear adjustmentLamp: 230w beam lights with bulbFantasy: eight prism effect controlFocus: independent electronic linear focusCooling system: built-in convection heat / airDescription trimming (x / y-axis precision): 8 / 16bitLevel of 540°, vertical 270°, horizontal / vertical speed adjustableEffect:pattern water effects / pattern jitter effect / linear rainbow effectControl mode: dmx512 / master-slave / auto / sync / voice / lcd displayFixed gobo wheel: 17 gobo patterns, made from high temperature special materialsPackage size: 42x 47x 58cm (16.5" x 18.5"x 22.8") /pcWeight: 22kg ( 48.5 lb ) / pc
  6. FOUND IT...NEvermind....
  7. I want to get rib of my pictures I used to pick colors from..but I don't see how to delete them!!!
  8. Great.. Thank you so much
  9. Does any body knows how to BLACK OUT all?
  10. Thank you I aprecciate mate !!
  11. Dammm.... That's to PRO for me...I leave it to the XPERTS
  12. SO... do I install this in to my computer?
  13. Ok.. Already send the e-mail Hope it doesn't take that long... https://www.monoprice.com/product?p_id=612751 https://www.monoprice.com/product?p_id=612788
  14. I just got my FLX S48. I have 12 of this, but the model does not apear on my desk list? What do I do...?? https://www.amazon.com/dp/B01COB6KZQ/ref=dp_cerb_2
