jb07
Everything posted by jb07
ok I succeeded (finally)
Hello I wanted to retry to update but impossiblem I do not understand. I downloaded the file PhantomZeroOS 7.9.4.23; I unzip on a blank usb stick the exe file I put the usb sitck on the console; setup and load the exe file; after the 2 warnings; I have an error : looking for upgrade package; file does not contain an Upgrade package; upgrade fail thanks
hellom the link is bad : Error code: 2S119/1
Hello I have copied the file "phantomZerOS 7.9.4.19 MD beta.exe" on the root of the USB stick setup; load file; select "phantomZerOS 7.9.4.19 MD beta.exe"; 2 advertissments and upgrade failled; File does not contain an upgrade package Thanks
I have fallow the instruction of the software cf picture If I go to load; I have no file on the USB drive If I see the usb drive on a computer; I have a directory "install" and a file "6q_bootscript"
Hello I have try the update but it doesn't work I have download and unzip de zip file I have execute the exe file with a new uSB drive I have plug the usb in the usb port of the rear of the console I have swith ON the console The software stay is the 7;9;4.3
Hello I've try to lauch remote on my android tablette m but the screen stay on a "Z" and a little "z" thanks
I have send an email, what is new with this version ?
Hello What is the lastest firmware ? on internet there are the 7.9.4 on my console I have :OS 7.8.1.2 and Software version 7.9.4.3 when is the new version ?
Hello It is possible to change a Output for do a DMX IN ? thanks
hello Press and hold the key "setup" and press the key "master playback" (triangle play) Select "GRAND MASTER" for the fader function and latch for the button function
Hello or you have to motorize the buttons!
is it possible to keep the potentiometers 1 to 12 permanently for the channels and the potentiometers 13 to 24 for the playbacks ? It would avoid switching with the key channels / playback
Thank you for the answers I just tried it works well. I am a beginner on this console I learn every day
I have try it's work thanks
hello thanks for the answer I have read de french manual but It's not always obvious to understand everything, sometimes I have to look in the original manual. For the other question, it is possible to export a chase for editing on a computer ?
Why it is not possible to delete one (or more) CUE in a program (chase) ? On all my other consoles you could delete a step or make a copy/paste etc... or it is possible to export a chase for editing on a computer ?
I have trouble setting my intimidator wave chauvet: look picture It consists of 5 RGBW heads and I can't get the "color picker" and the "tilt grid" for each head When I declare the fixture in fixture type editor it is not possible to put 5 Tilts or 5 reds positives. I would like to have the same functions as 5 lyres for 1 fixture with 5 heads thanks for your advices
Hello, I'm French, so sorry for my poor English. (thanks Google). I would like to have a visualization of my programming without using wisiwig which is much too complicated for me. I only have 4 lyres and 8 RGB spots. I would like to have a visual of my programming without having to plug everything. thank you in advance for your help
