CJD007
Everything posted by CJD007
  1. Hi, Thanks again for reply. It happens on all movement effects when slowed right down.I've checked DMX output while running the shape and it looks ok. Just tried same on a different make/model fixture and looks loads better (still small amount of stepping but nothing too noticeable)so obviously something in the way the 5R is dealing with the information. I can get a good smooth slow scan on the 5R from a different console. The Chauvet R3 Spot I tried doesn't home with shutter open so lifting the channel fader doesn't bring light up, is this an easy fix (or intended?) Thanks
  2. Thanks for quick replies. Elation Platinum Spot 5R - Extended Mode No Effect then reapply effect = no difference Size 20, Speed 8 = Noticeable stepping (in warehouse, 5m throw) Increase to Speed 12 = less noticeable at speed but clear stepping when slowing down at the end of travel and restarting return journey.
  3. Quick one...... When powering up console it starts in channel mode. Is it possible to have the console start in Playbacks mode? Thanks
  4. Hi, Trying to get a slow pan sweep on some fixtures. Chose horizontal effect and works well at speed but when slowed down it appears a bit jerky. Not had this on other consoles, is there a way to make it smoother? Thanks
