AlexTec
AlexTec last won the day on January 17 2024
AlexTec had the most liked content!
AlexTec's Achievements
  1. Thanks for the quick reply. I'm sorry I misunderstood something here, now I know how to do it right. Kind regards AlexTec
  2. Hello Edward. I use FLX S48. Moving Head Eurolite LED TMH S90 Eurolite LED TMH-S90 Moving-Head Spot – Musikhaus Thomann is not in the Device-Library. I built it myself using the Fixture-tool, unfortunately it doesn`t work perfectly. can i get a Fifture file fromyour site? King regards, Alex. Mail: stadthalletechnik@boppard.de
  3. Thanks for your reply Edward. I'll try it via "FixtureSupport". Kind regards, Alex
  4. Hello Edward. I have a problem with the "Stairville B5R" fixture. The device is present in the library, but the gobo icons are not displayed. The parameters are absolutely the same as "Clay Paky Sharpy". I re-created the Sharpy, gobos are shown. How can I apply the Sharpy icons for B5R so that the gobo image does not disappear? Is there a trick? Kind regards, Alextec (Translated by google translator)
  5. you can feed the devices indirectly via dmx. For example via DMX Switchpack (BeamZ 4 Chanel DMX)
  6. I disabled RigSync and that solved the problem pretty much. Thank you for helping out.
  7. Thank you
  8. Hello. I have new FLX S 48 512. Fixtures from library reissued, working except 6 Cameo LEDStudioPar64. Software 7.9.4. 6Ch-Mode, 9Ch-Mode tried - all colors flakern (like Strobo). Cable plugged into a MA console - no more flickering. Where is the problem ? Thank you
