marcopolo
Everything posted by marcopolo
  1. I think I have confused myself - thanks for being patient! I was looking in the pallette for the effect and half remembering the upload of the zbr file from a previous time, when I actually did have no palettes! Sorry, a touch rusty after 2 years ..... I have all the effects had just skipped over them. More haste less speed .....
  2. Thanks! I have reloaded the show file, but the auto generated show palettes I had before will not "regenerate". So whilst the uploaded show works just fine, I cannot for example create a new figure of 8 pattern with my lights. This happened once before and I was given a file to upload and it all worked just fine again.
  3. Hi. I have a moving head set up on the desk and have pushed create palette. I still have no palettes. This is immediately after an upgrade to latest version. There were position palettes before the upgrade. Is there a missing file to upload? Thanks
  4. marcopolo
    Update issue
    Solution worked - Thanks for quick reply
  5. marcopolo
    Update issue
    Will do - submitted a rely to the main post - it happened once before prior to upgrade .....
  6. I noticed issue before the upgrade. I loaded a new show from scratch. It happened once and then went away. But I reloaded the lights in between ..... and built the effects after only loading 2 moving heads. Only different feature was adding in my Clay Paky HPE 700 lights after the effects creation with just Prolights lights, so I originally though it was the mix of lights blocking it. Then it worked again and forgot about it. Did the upload and oops cannot get it back at all. This time however also more serious as cannot even see the sine wave etc. So not just the auto upload missing. Will upload the file tomorrow. But maybe that it happened before is a clue? M
  7. Sorry posting again here - I seem to have lost all effects. The macro does nothing. The drop down menu with sine waves etc has nothing in it. Going to need this pretty soon!! I only upgraded forthe new effects and now I have none at all. LOL
  8. marcopolo
    Update issue
    I have just uploaded the update ZerOS OS Creator USB - v7.9.5 17-5-2019 MD.zip It went on fine so I am on v 7.8.1.2 and have 7.9.5 installed. I put it on for the new effects. Sadly there are now no effects at all. The macro does nothing and I dont have the drop down menu for sine waves etc. HELP!! What has gone wrong? Thanks Mark
  9. marcopolo
    Updated Manual
    Thanks - that will help a lot
  10. If you want more specific info I will give it to you. I had to look at the wireless card in the fixture Prolights Stark 400 to work this out sending serial numbers and software versions to W-DMX. It is to do with frequency hopping I understand. But quite surprising that one wireless Rx unit with a problem in a fixture can upset every fixture (even those on different G5 Rx - Stairville- units without the problem). Initially you think it is the desk or the Tx W-DMX T1 G5 as the only possible cause ..... Waiting for the fix at the moment as G3 is not exactly the most up to date solution in a new light!!
  11. marcopolo
    Updated Manual
    Please please please can you update the crib sheet soon. I really need it when I go into schools. This is your future customer base !! They just want to get stuck in and not sit down with the videos .... Think cheat sheet and you have them. Is it a long till the next version is out????? Thanks Mark
  12. Thanks - I have sussed the problem. It would appear that the fixtures have old firmware within them despite being new fixtures. Have reverted to G3 and it all works. I had not realized that a fixture downstream could affect all the others.
  13. Hi guys Has anyone experience of using the FLX with the W-DMX G5 products? I cannot get a glitch free signal: The movers suddenly and randomly all twitch together, some lights randomly flash full on simultaneously. It will hold good for 5 mins and then start a run of glitches every few seconds. Then hold good. All lights get the same glitch signal independent of Tx unit or Rx unit. I have turned off RDM on the FLX. If I take the W-DMX Tx box out and insert a Stairville compatible Tx box, I get the same glitch. If I have four separate Rx units all on different addresses, the four fixtures, all twitch the same time in the same direction so the erroneous signal is going out to all units and is identical (Substitute a wire, it is not there). Help gratefully received! Thanks
  14. marcopolo
    Updated Manual
    Hi Edward - did you do this? Thanks Mark
  15. Prolights Eclipse Fresnel, is it beyond an upgrade or just a question of waiting?
  16. Hi My LED Fresnel has these colours: red, orange, green, royal blue, blue, lime I am not sure how to convert the standard RGB filter board and colour picker to take advantage of this colour set up. I seem to be doing a lot of manual colour selection! Any clues? Thanks MArk
  17. marcopolo
    Updated Manual
    Thanks a quick reference sheet would be brilliant, does not need to include the setup phase, but to include this too please http://support.zero88.com/Legacy-Products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/1011707591/What-does-the-Output-Window-show.htm Plus a quick bit about Cues and Tracking as that catches everyone out and they end up in a mess! Mark
  18. marcopolo
    Updated Manual
    Thanks for the above. I found this in the repositories of your site. It is not 100% right, as it is for a different desk (Orb) but very useful: https://zero88.com/manuals/orb_quick_reference_sheet_issue_1.pdf Any chance of a full one for the FLX? It saves a lot of time when introducing people to the desk!
  19. marcopolo
    Updated Manual
    Hi I note there are several significant changes with the new FLX software especially in setup. Is there a manual update as the current version as an example among many things that differ shows a home setup screen I cannot find any more in setup etc. Thanks Mark
  20. Hi. I am using the fixture editor to create my own fixture. I have a very simple LED controller. it has 8 channels and controls two separate LED strips. It has 8 channels, and I have set up one virtual to dim. Two problems: A) I can get one strip on the colour picker but not the other. Is there any way to have two colour pickers for the one DMX address? B)A would be fine if I could get the two strips to operate as one. But this is also out of reach! I have had several test runs - how do I delete the incorrect .ift files from the FLX Thanks - Mark LED Strip 5.ift
