francocampo
2
Everything posted by francocampo
Hi all forum. Sorry for the trivial question is it possible to change the reset position of the moving heads, i.e. when I release a playback with release lower enabled the moving heads go to a position chosen by me, I have tried to keep release lower disabled but then problems arise with colour changes and various beamshapes. thanks always for your availability i apologise for my English and for the trivial question. Very best regards
Many many thank's Edward Best regards
Hi kgallen thank you for your interest, I would like to make sure that when I change playback the moving heads do not go to home position and then move to the cue in playback. Thanks for all, best regards
Thanks again Edward and kgallen, actually the problem is that when I switch from one playback to another the moving head lights first go to home position and then go to the programmed cue. so when the current playback goes to 0 the lights remain in the same position and when the other cue is played back the lights do not move. I hope I was as understandable as possible. I apologize for my English and I wish you all good. Thanks again
Hi kgallen thank you very much for your reply.
Good morning If possible disable reset position of moving head when the playback go to 0. Excusme for my English
I have always worked without problems with my solution and I am very satisfied with it but one day it crashed and I saved the debug that I was asked to send. Thank you for the work you do to keep our consoles efficient. Thanks and good job. Excusme for my English Best regards Franco Campolattano debug_12-7-2020_01-30-02.zdb
Thanks again.
Thank you so much for your quick responses. Very Best Regards and excusme for my English.
Hi everybody, my new solution has ZerOs 7.8.2.39 I wanted to ask if it is better to update first for example 7.9.2 and after 7.9.7 or directly to 7.9.7. Thank you so much for any replies. And sorry for my english
Very slow page change (Leap frog 96)
francocampo replied to francocampo's topic in Leap Frog 48 & 96
Kind Edward I noticed that when you load a playback page on its display a white bar lights upand before the update it fills up when playback was performed. Thank you very much, good weekend. Excusme my English. Franco -
After updating to version 7.9.6 when I change page of playbacks I have to wait to work with playbacks. There is a way to speed up the change. Thanks for the possible reply and sorry for my english. Best regards
Dear Edward, I thank you infinitely for the answer and I wish you all the best.
Good morning, if possible can back on the playback with varius cue, for example in my playbabk there are 3 cues, with botton under fader if possible go next cue, if possible back the cue? Excusme for my bad English, thank you for response. Best regards
Dear Jon ok no problem, thanks again and good work.
Dear Jon Hole, first of all thanks for your quick response, no because the cue before the problem worked properly then once done reset and loaded the show everything works perfectly, at some point the playback give that problem. thanks again
hi I'm a lucky owner of a lp96, it happened to me that during the preparation of a show the playbacks when operated commanded only dimmer no pan or tilt and no beamshape and second cue not funcion completly, I noticed that the led on the flash button when the playback is operated is not lit steady but flashes, to solve I had to reset the desk, can I solve it in any other way? Software in use 7.9.4. Thank you and sorry for my bad English.
