dlboyd
Everything posted by dlboyd
  1. Following some experimenting, I have solved one problem. To change current lighting state, select "Next" as the same Memory you are on and then go into "Program" mode. Make changes, reselect "Run" mode and you will be on the same Memory step. Don't forget to then select the Next Memory! Might be useful to put this info in the Operating Manual.
  2. In Run Mode it is possible to raise a channel level, but it would also be useful if you could "capture" and lower it. and/or when you select Program Mode from Run mode, it stayed on the same Memory Step so that it could be Edited. At present, it goes to the next memory step if you switch from Run to Program. Another thought is that the Output stays in Run Mode thereby enabling "Blind" editing of memory levels when program mode is selected. Currently the Output goes to the levels of the scene memory selected when switching between modes. This means that it is not possible to reprogram a memory whilst running a show which can be a major disadvantage.
