Peter6442peter
Peter6442peter's Achievements
Explorer
Explorer (4/14)
  1. Yeah but in 2 way mode the cue won't change. Before the last update I could fade without the cue changing and the go button changing the cue. Say for tab calls at the end of a show. Instead of programming 4 or 5 cues up and down. I have come to the last cue in the stack and then use the master fader to operate how many calls I need. Oh and the desk crashes so I have to reboot. Hope that all makes sense. Congrats on your Marriage. Hope you and your wife are both Happy Pete
  2. Am trying to use the master playback as a up and down fader. Eg fade the light bup and down for a particular cue. In settings the htp master fades the lights down the triggers the next cue and fades the lights up. Fade 1 way triggers next cue down and next cue up. Fade 2 ways fades the cue but the go button doesn't work. Have rebooted desk several times but doesn't make any difference. Anyone have an answer to my problem
  3. Cheers Ed will have a go
  4. HI I have just purchased 6 Chauvet Colorado Zooms. My issue is when ever I push up a fader with memory on it the fixture snaps on at about 20percent and then fades up to full eg Red 100% Blue100% Green 100% White100% and then falls back to its programmed colour say Straw. When I pull the fader down the last 20% the fixture snaps off. You told me how to remedy this on your course but am afraid I've forgotten. Pete
  5. Hi Can i fit a 2nd universe myself is it straight forward if I can or does it have to go back to zero88 how much does it cost.
  6. Hi have noticed that the latest upgrade is v7.9.7. I have missed 3 upgrades. I am on v7.9.4., for some reason. Is it safe to just upgrade straight to the latest release.
  7. How do i rectify this please
  8. Need a dummies guide to fix this please
  9. No fade up or down on encoder wheels either
  10. No fade times showing on master play back except cue one. So everything is a snap. Default fade times are 3 secs. Have rebooted board several times Pete
  11. Sorted Ed it was a trigger problem. It works OK when release on down is enabled
  12. Hi I have 4 Robe colorspot 250at along front of stage. I have on playback 1 a chase each fixture following on from the other 1234. On playback 2 I have another chase this time the four split in 2 pairs 12.but when I put playback 1 up and it starts running OK. Then I put playback 2 up which should be different to playback 1, it mirrors playback 1 and then I can't get playback 2 back although when you view the playback on the screen it's showing the 2 steps. Hope that makes sense. Tech tomorrow evening
  13. Flx s48 In the cue stack am wanting to leave a gap to insert fade out tab warmers and then fade out when ive got time after rehearsal. So I'm on cue 25 so the after the 3 cues my next cue will be cue cue 28. How do i achieve this?
  14. I am attempting to link my FLX 48 to my PC in order to use the free Club Capture show file. I have tried with a crossover cable and fixed IP addressing on the 192.168.0.2 PC and the board set at 192.168.0.4 I have also attempted the same as above but with a network switch using CAT 5 cable. Also, a router on the same range DHCP but to no avail. Is there something else I am missing out here or can anyone point me in the right direction? Rang helpline the other day, they said it wasn't pinging because of no default gateway but the router should become the default gateway on DHCP. No lights are flashing on the switch or router when I pull up a fader on the board itself - surely this can't be right?
